Author Topic: Oil cooler plate leak  (Read 3809 times)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
« on: 12 January 2018, 21:41:14 »
Hi guys, last year I found a cause of coolant leak and decided to sort it out at the same time as cambelt which is planned for this summer.
The question is: Is it adviceable to replace entire oil cooler while I'm there or just reseal an old cooler plate?
Oil cooler isn't mixing oil and coolant  for now.
If anyone has any parts laying around  I could use here, let me know.
Thanks in advance, Stan
Re: Oil cooler plate leak
« Reply #1 on: 13 January 2018, 02:08:08 »
Might as well replace it if you're already stripping it to that point. Do the thermostat as well ;)
danzigfan
« Reply #2 on: 13 January 2018, 07:43:31 »
Those were my thoughts exactly, thanks :y
Is this sealant the right one for oil cooler plate seal?
https://m.ebay.de/itm/Vauxhall-Dichtung-Verbindung-Original-93165267/152320018159
amba
  • Medway towns
    • German V6
« Reply #3 on: 13 January 2018, 08:51:35 »
That's the stuff :y.
Ensure you seal all around each bolt hole on the outer edge....mastic gun is needed
« Reply #4 on: 13 January 2018, 10:26:20 »
Good call :y
As for actual cooler, depends on history.  Its believed, apart from very early ones, that poor coolant servicing killed them, rather than age.  So if unclear, worth changing, if you know its been well maintained, you can save the cost.
My 19yr old MV6 was on original cooler when scrapped.
danzigfan
« Reply #5 on: 13 January 2018, 11:03:47 »
Well I changed coolant 3 years ago...it was blue coolant in it before. I'll change oil cooler for the sake of it while it's all apart, just need to find all bits and pieces now.
Thanks
« Reply #6 on: 13 January 2018, 12:02:00 »
Cooler was around $149 and stat $35... pipe is $12.
Uk prices the same numbers, but in £. All genuine :y
danzigfan
« Reply #7 on: 13 January 2018, 12:18:23 »
Yes I saw, will order oil cooler from your country - it's cheaper than from Germany, already have the stat, reuse the pipe - just replace O-rings, already have water pump and aux belt pulley prepared. Only things to get now are washers for coolant bridge, cambelt set and aux belt. Then just some rust repair in summer and I hope she'll be fine for next 4 years.
https://m.ebay.com/itm/Original-Opel-Signum-Vectra-V6-2-5-3-0-3-2-Olkuhler-Kuhler-93176626/201916893395?fits=Model%3AOmega&hash=item2f032f48d3:g:fD0AAOSwe0NZ2447
This one should do the trick
« Reply #8 on: 13 January 2018, 15:23:07 »
Indeed it should ;)
« Reply #9 on: 15 January 2018, 09:33:37 »
Its not uncommon for the threads which hold the cooler to the cooler plate to strip when the fixing nuts are removed so having a replacement cooler is a good move.
Don't forget the metal washers for the banjo bolt that connect the cooler pipes to the cooler.  :y
danzigfan
« Reply #10 on: 15 January 2018, 11:16:44 »
Those are the bits I need to find yet, thanks :y
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #11 on: 15 January 2018, 19:58:57 »
Main dealers sell those washers for not a lot of money.However when I bought my oil cooler it came with the washers included,the only "extra" bits I needed were the Dowty washers for the coolant bridge-and the grey sealant of course.
