Author Topic: headlight level sensor  (Read 10509 times)
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: headlight level sensor
« Reply #15 on: 09 February 2018, 22:02:23 »
when they bring up the field vision error message is it because it has detected the sensor has gone open circuit ? .and can they fail in other ways too.like no error messages but no signs of lights moving ? .
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #16 on: 10 February 2018, 13:36:58 »
pic as promised,a lot of stuff going on inside so any water ingress may be terminal but may just need some resoldering.
cam.in.head
  • West yorkshire
« Reply #17 on: 10 February 2018, 15:48:22 »
 So been reading somewhere on here that its a hall effect and uses a magnetic arm to give position and some say it may be a pot. Can anyone confirm either. If it was a pot and the arm came off surely it wouldnt bring up a fault as the shaft is designed to move anyway it just wouldnt be indicating what the suspension was doing . . .?    Just curious how it operates .thanks.
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
    • Grischke Solutions
« Reply #18 on: 10 February 2018, 15:53:36 »
Bloody hell, did you manage to put it together afterwards with no issues?
Magwheels
    • 2.2 dti Elite saloon
« Reply #19 on: 10 February 2018, 18:43:56 »
Mine was magnetic and the arm itself fell out and disappeared....no repairing that one!!
laney101
  • liverpool
    • omega elite v6
« Reply #20 on: 14 February 2018, 06:02:46 »
I managed to swap one over eventually ...
There's the bolts holding them to the subframes and screws holding them to the brackets.
If you can't undo the brackets, then you're clearly not trying...
Was trying but apart from grind them off re drilling and tapping weren't moving ...
I'd always rather fit new parts when something like this regardless of cost...
Could be there Unsoldering every joint and resolder get back on and still doesn't work ... Lots of effort and time wasted ...
If can be bough new I'd rather just buy new... Or if someone selling a known good pair swap to at once with brackets
Front cooked now as broke trying to remove of bracket
Rear not been touched
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #21 on: 14 February 2018, 12:30:25 »
agree that resoldering every joint is not feasible but the 3 obvious main contacts are easy to spot.personally I'm not prepared to spend £100 plus for a single part when the complete car was bought for £150.
« Reply #22 on: 14 February 2018, 12:53:17 »
These are hall effect devices and tend to suffer 2 failure modes:
1) The ball joints on the arm get stiff due to water ingress and eventually the extra force distorts the plastic body of the sensor, water gets in and game over.
2) The arm comes loose and drops out of the sensor body. Sometimes it will snap back in and, if the ball joints are freed up, it will be fine. Often it won't.
The mounting screws securing the sensor to the bracket are usually siezed and unless you're very careful the plastic housing will crack as you try to unscrew them.
Basically, a bit of maintenance, freeing up and greasing the ball joints every so often, will keep them in good condition.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #23 on: 14 February 2018, 12:54:33 »
Dave the ones on my current breaker are giving codes for being unserviceable, if that's the case you are welcome to cannibalise them for bracketry or casings, Ps the stereo works fine !
cam.in.head
  • West yorkshire
« Reply #24 on: 14 February 2018, 15:43:15 »
thankyou to kevin above for that description. out of curiosity although mine doesnt give any warning messages and the lights are aligned  fine when driving there doeasnt seem to be the initial movement people say happens at first. what are they supposed to do.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #25 on: 14 February 2018, 18:33:14 »
On mine they light up then "dip" and then rise a little[guessing somewhere between the initial light up and the "dip" position]
« Reply #26 on: 14 February 2018, 19:25:38 »
This is the normal function test. If they don't do it then summat is not working properly.  :y
Automaticman
  • Neston
  • Saxwood
    • Frontera V6 Omega V6
« Reply #27 on: 22 February 2018, 20:13:08 »
Same message on mine now I know what it means, where is this irksome object to be found, me being new to all this so please forgive my ignorance in advance ?
When ya wanna shoot, shoot, dont talk !
BazaJT
« Reply #28 on: 23 February 2018, 19:22:09 »
I believe there are two levelling sensors one on the n/s/r suspension and one on the front suspension-but I can't recall which side.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #29 on: 23 February 2018, 19:26:47 »
Nearside Baza. :y
Page created in 0.031 seconds with 20 queries.
