Author Topic: I really AM a muppet  (Read 2177 times)
« on: 11 August 2008, 20:02:42 »
I should be ashamed of myself. I've been sat thinking for ages about why this V6 isn't nearly as economical  as any others I have owned, and I've just realised the answer. The bleedin' thing was overcooling, temp gauge was far too low. I reckon the stat's stuck open...
stuart30
Re: I really AM a muppet
« Reply #1 on: 11 August 2008, 20:17:30 »
James could you eplain in idiot terms (so i can understand) the difference a thermostat being stuck open would make...and what is regarded as too cool. :-?
I know obviously over heating is bad....but under heating. :-[
Bandit127
« Reply #2 on: 11 August 2008, 20:19:06 »
James, taking a week to link poor consumption and low temp is not worthy of harsh words like "muppet" and "ashamed" You are well respected here for being a likeable, clever and helpful fellow. Give yourself a break mate.  :(
On the other hand, dropping half an HT lead down the plug hole, well.....  ;D ;D ;D
« Reply #3 on: 11 August 2008, 20:19:10 »
If the engine runs cool, the Coolant temperature sensor will tell that to the engine ECU, which will then think it's running cold, and hence inject more fuel...
stuart30
« Reply #4 on: 11 August 2008, 20:21:08 »
Oh blimey.. :y
What would be classed for running too cool....and would that be assumed from the temp gauge or externally monitored.
Bandit127
« Reply #5 on: 11 August 2008, 20:31:26 »
Oh blimey..  :y
90 deg or below.
What's probably happening is condensation of the fuel mixture. It's been a problem for a lot longer than ECUs have been around.
I got about 5 mpg back on a 1968 Escort by replacing the thermostat.
A long time ago... :)
platty
  • Cambridge
    • BMW 530d Sport
« Reply #6 on: 11 August 2008, 21:00:48 »
This has got me thinking now... my motor never gets above 90 degrees unless in traffic on a real hot day where it might scrape 92-93 ish.
Could this be affecting my consumption then?  :-?
Omegatoy
  • UK
« Reply #7 on: 11 August 2008, 21:19:58 »
yep td should run around 90 mate!!! changed mine cos it never got hot enough way back when i first got it then spent the next three weeks worrying about it running so hot!!! but it made a difference to the economy for sure, it also made the temp go up to 98 99 on long hills but as soon as it gts on the flat it comes back down to 90ish again almost straight away, and being as regular temps here are 36 i keep a onstant eye on me temp gauge but same thing happens  it always runs just over the 90!!! :y
« Reply #8 on: 11 August 2008, 21:35:27 »
James, you a muppet :P
TD owners, if cooling system is up for it, should run just below mid point, rising to just over midpoint after a thrashing, as per all Omegas.
« Reply #9 on: 11 August 2008, 21:48:16 »
yep..good scientific explanation :y
v6coop
  • Nottingham
« Reply #10 on: 11 August 2008, 22:19:42 »
Would it be worth getting a Tech II check on the temp reading that the ECU is receiving? I think we have heard that the reading the temp gauge gives and the coolant temp from the ECU sensor can be very different and it is what the ECU is getting that is important not the instrument panel reading.
Danny
  • Wigan, Greater Manchester
« Reply #11 on: 11 August 2008, 22:44:41 »
i think mine has this problem, only goes over 90 when i'm stuck in traffic...?
« Reply #12 on: 11 August 2008, 22:50:32 »
90 is midpoint on guage on facelifts. midpoint is what you are aiming for!
Danny
« Reply #13 on: 11 August 2008, 22:54:44 »
only when i'm in traffic though? sits quite a bit lower on regular driving
« Last Edit: 11 August 2008, 22:55:04 by D4NNY »
« Reply #14 on: 11 August 2008, 22:56:21 »
how much lower?
