Lawn protection.
Started by Bigron, 31 January 2018, 19:58:21
Keith ABS
 would it not be beter to donate the caravan to Clarckson, Hammond and May? We then all get to see the amusing end results, foreever if it gets on to Dave :) :D ;D ::)
Keith ABS
Bigron
Quote from: Bigron on 01 February 2018, 09:01:38
Sometimes I get really useful help here..... ::)
Ron.
But not always, eh Keith?  :(
Ron.
BigAl
Quote from: STEMO on 31 January 2018, 20:11:05
Quote from: Doctor Gollum on 31 January 2018, 20:04:29
You can get plastic grid squares to provide support whilst allowing grass or gravel surface :y
http://www.drainageshop.co.uk/groundgrid/GTE001.html?kw=pla-326453452220+m&fl=1000&ci=201616114044&network=pla&gclid=CjwKCAiA78XTBRBiEiwAGv7EKlPJSjJR8jXx0vCypbbbAAUEJOyKAklKTZrh-rTWa-kRbmHh2W8U5BoCPLUQAvD_BwE
They don't work on wet, muddy grass, only when it's nice and dry. They just sink right in and your back to square one. Admittedly, I bought it on a roll and about half the thickness of that, but it had disappeared within a week.
those grids are similar to the ones i used when i converted the front garden into a 2 car drive a couple of years ago, filled with gravel, they work very well
Bigron
That's encouraging, Al - pea shingle or larger?
Ron.
jonathanh
those grid systems do work but it is absolutely critical to use the right sub base and work out drainage levels.  Neighbour of mine has the stuff set on non draining sub base in a clay field where it was lower than the surrounding field.  you can guess the result.
Bigron
Thanks for that, Jonathan. My lawn is turf laid on Essex clay, no specific drainage allowed for, so it looks like I have a problem!
Maybe I should park on the road until I have saved enough pennies to get it block paved or concreted?  :(
Ron.
biggriffin
Burn the caravan, problems solved :D
Hoof'land storeman.
henryd
Quote from: Bigron on 02 February 2018, 10:04:01
Ron.
As the caravan moves less often than the car why not swap them around,kill the grass then a membrane and a couple of tons of chippings will stop grass coming back :y
other rides
Bigron
I did consider that, Henry, but I np longer have a towbar and no way could I move it by hand, even with several strong blokes and my lawn slopes and is now slippery too!
If I did the lottery I could use my winnings to concrete it over buy a country mansion.....
Ron.
BazaJT
Couldn't you just wedge a brick behind a couple of the wheels?
I think we need a picture of your tin tent Ron!  :y
