stalled
Started by grifter, 06 February 2018, 07:30:55
grifter
Quote from: Migv6 on 19 March 2018, 19:52:33
If Fuse 19 is advising MAF, then I would be looking there before anywhere else. Unplug the MAF and see if the symptoms change.
Is there a guide for doing this?
Can you read the live values for air flow and the learnt values for mixture?
If by a guide you mean, "unplug it and see if anything changes..." then yes, there's a guide ;)
grifter
Quote from: Doctor Gollum on 20 March 2018, 00:24:10
No, how to actually change it lol :)! I found it anyway but cheers
Got to take scuttle off again bummer, is there anything on this car that doesn't require that bloody scuttle removed?
Quote from: grifter on 20 March 2018, 06:45:58
No, how to actually change it lol :) ! I found it anyway but cheers
The MAF is attached to the air filter housing, behind the drivers headlight.
deviator
I don't mean to be rude, but if you don't know what a MAF looks like or where it is, I'd probably get some help.
Anyway, as well as the above suggestions, look for split pipes (air to plenum) and split vacuum pipe end. Also, it is worth checking the throttle body to see if it's gunked up.
grifter
Quote from: deviator on 20 March 2018, 09:56:49
It's no prblem i know where it is. I just put that all back together last year after doing timing belt. Everything looks fine but will check agsin. If i dont see anything obvious what is next step with maf?
Quote from: grifter on 20 March 2018, 10:48:21
if you had the tech, tools and experience you could examine how well it is functioning.
As you don't have those, disconnect the electrical connector on the MAF, and drive the car. This will put the EML on, but if the actual problem is no longer present then buying a quality new MAF is your next step.
But you're already breaking the first rule of diagnosis by not going back over the work you did before the fault.
grifter
Quote from: Nick W on 20 March 2018, 11:25:40
If you mean the timing belt work, that was done about a year ago and have checked this area multiple times, and once more tonight.
Going by this advice I unplugged the maf multi plug (the one under the left air intake bagpipe thing right?) and the car struggled to start and when it did the gearbox seemed to lock into a high gear and it wouldn't move. So I guess that didn't work either. I then plugged it back in and the car ran fine.
I have a friendly contact in the AA who has said that he can check it. I don't know if this will give a diagnosis or just codes, but it won't hurt, my 2nd option is a guy who does tech2 near Glasgow. I will take it there and see what if anything they can find as this is doing my brain in now.
Presumably the fuel pressure regulator vacuum line is still connected to the bottom of the throttle body?
grifter
Quote from: Doctor Gollum on 20 March 2018, 19:49:29
That is the pipe that comes along the middle of the banks and plugs up the way into the body, if so yes I've checked all the vac lines all around there and on the multi-ram bits as well.
grifter
The plug that goes onto the maf (i think) was broke, i knew about this but it still slotted it quite firmly, is now tie wrapped tight into the plug & loanbehold the light on dash (eml) is now out!
grifter
Quote from: grifter on 25 March 2018, 20:08:49
Nope I had the plug off the throttle sensor I think so no wonder it wasn't working. Anyway the fault cleared - for a while - now it is back on. I will take off the MAF plug this time and see what happens.
