Author Topic: meg tank does it fit senator?  (Read 3901 times)
grifter
  • Paisley, Scotland
    • Omega 2.6 CD / Elite 3.2
« on: 07 February 2018, 10:45:58 »
As above, new teplacements are really expensive, and metal so thinking plastic meg one would be beter option
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: meg tank does it fit senator?
« Reply #1 on: 07 February 2018, 12:55:20 »
In English please.
Hoof'land storeman.
« Reply #2 on: 07 February 2018, 13:06:38 »
Easy to read here.....
Replacement senator ones are expensive and metal. He is asking if Omega plastic fuel tanks fit a senator.
Would imagine they are different as in the straps and mounting points? Perhaps need custom version of them?
« Reply #3 on: 07 February 2018, 17:38:26 »
What's a meg?
grifter
  • Paisley, Scotland
« Reply #4 on: 07 February 2018, 18:04:00 »
Will ask at ABS too as it's more likely someone there done it.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #5 on: 07 February 2018, 19:40:38 »
Might it also differ if it's a Senator A or a B you're talking about?IIRC the Senator A had a fuel pump mounted ahead of the tank where the Senator B had an in tank pump?
« Reply #6 on: 07 February 2018, 21:16:20 »
I'd be amazed if the two tanks are anything like each other.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #7 on: 07 February 2018, 22:04:18 »
Pretty much the same chassis, so I wouldn't like to say one way or the other. I cant remember what my Senator tank was like tbh.
Never needed to get under it very often.  :)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #8 on: 08 February 2018, 05:57:40 »
grifter
  • Paisley, Scotland
« Reply #9 on: 08 February 2018, 07:37:47 »
Senny b it is
« Reply #10 on: 08 February 2018, 08:19:50 »
I would be very very surprised if it did fit, they are blow moulded plastic and any slight change to chassis etc would alter the shape.
The sender and fuel take off is very different, from memory, on the senator, it is mounted on the side, the Omega has it on top (might be possible to alter the pipe work and prey the level sensor has the same resistance profile as the senator one).
The filler connection is also different.
