Author Topic: 2.6 ps pump part number  (Read 2185 times)
9jdm
  • Lancashire and Ireland
« on: 09 February 2018, 22:10:31 »
Few questions re pump
Mine is noisy since I had to drive it home with no fluid in.
1. What is part number for 2.6
2. Will it fail or jam up if I continue to ignore it for time being
2. Can they be repaired or is there any other versions that will fit?
Thanks
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
Re: 2.6 ps pump part number
« Reply #1 on: 11 February 2018, 18:01:08 »
would replace it, should not let the power steering pump be low as it will overheat, can even fragment and get into the steering and then you would need to replace or repair this part as well.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 12 February 2018, 14:41:13 »
2.6 and 3.2 use same pump, totally different to 3.0/2.5 pump.
Hoof'land storeman.
