Author Topic: Mini Cooper Exhaust Q...  (Read 3667 times)
« on: 13 February 2018, 17:20:41 »
As above, 2006 non S 1.6 petrol.
Lass at work has one with a detached back box ::)
Looking at it, it's a single pipe to the cat flange.
Question is this: are the studs on the cat pipe or the main exhaust?
Looks like a straightforward enough job once the car is off the ground, and the exhaust itself is cheap enough... :y
Re: Mini Cooper Exhaust Q...
« Reply #1 on: 13 February 2018, 18:06:13 »
How is she paying?  ???  ;)
« Reply #2 on: 13 February 2018, 18:35:41 »
Yes...a very 'gender specific' car. :)
« Reply #3 on: 13 February 2018, 18:47:13 »
Oh I don't know, I always thought the Cooper S would be fun to hack about in.  :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #4 on: 13 February 2018, 18:48:36 »
Yep,one piece from cat back,dont remember which way round its attached ::)
other rides
« Reply #5 on: 13 February 2018, 18:53:37 »
Nancy boy. :)
Are you a hairdresser by trade? ;)
iansoutham
  • SE London
    • Omega 2.0 m/f/l est CDX
« Reply #6 on: 13 February 2018, 20:24:29 »
2 piece from the cat back on a Cooper S.
The studs are on the rear section, that goes to the rear of the car and off to 1 box while the other box joins accordingly. Hard to describe but simple when you see it.
You also need 2 sets of clamps (1 set for each box) and be careful of the studs on the boot floor as they will shear off from the body if you are not careful.
iansoutham
  • SE London
« Reply #7 on: 13 February 2018, 20:25:39 »
« Reply #8 on: 13 February 2018, 21:12:47 »
Nancy boy. :)
Well I did have a girlfriend once who liked me to give her a trim now and again!  ;)  :)
« Reply #9 on: 13 February 2018, 21:31:41 »
Ta, but not the S ::) so only one back box...
Existing rear cage and mounts in good condition, so if I do this, I would be aiming to reuse the cage and leaving mounts alone ;)
iansoutham
  • SE London
« Reply #10 on: 14 February 2018, 05:43:32 »
If the bolts that hold the clamps together come undone, then yes, reuse the clamp as pattern ones cause the exhaust to hang low.
You will need a new gasket at the front of the pipe. Do you have the chrome line exterior pack (chrome trim on the exhaust)? If you do, it does not fit pattern exhausts right so most people end up leaving it off.
