Pages: 1 2 [3]  All   Go Down
Author Topic: Do you know someone or garage who can do a cambelt change on 2.6  (Read 11079 times)
Re: Do you know someone or garage who can do a cambelt change on 2.6
« Reply #30 on: 25 February 2018, 12:50:31 »
Deleted please disregard.
Just seen you have a local
Help offer :y
« Last Edit: 25 February 2018, 12:52:17 by JamesV6CDX »
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #31 on: 25 February 2018, 14:54:34 »
I thought that it was the tensioner pulley that failed  rather than the belt. If you are doing a cam belt change don't cut corners it could cost you a lot of money let alone the grief when the car breaks down.
Not that it matters, but I thought it was the pulley bearings that stiffened, causing the belt to come off and disaster to ensue. I have twice experienced auxiliary belt derailment, which is bad enough but does not destroy the engine.
« Reply #32 on: 25 February 2018, 15:18:49 »
All kits should have new tensioner, and the tensioners are all identical.
Its the backing plates and lower idler that vary
Pages: 1 2 [3]  All   Go Up
