Pages: 1 [2] 3  All   Go Down
Author Topic: Vectra vxr 345mm front Brake swap?  (Read 14207 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Vectra vxr 345mm front Brake swap?
« Reply #15 on: 18 February 2018, 15:55:35 »
Ignoring MK, there aren't too many places in the UK where under normal conditions you can really cook them if they are well maintained, without driving like a real loon, but you can easily get a bit close for comfort on a spirited country lane jaunt.
Apparently you can cook them running up from the M4 to Brackley, especially on the last few roundabouts :-X ::)
Back in the 80's I ploughed a Brand New Cav 130 SRi into a Round About on them roads due to Brake Fade, from MK to Buckingham.  :(
I was actually on the way to SuperChips for a Rolling Road Test, never made the Appointment though.  :-[
« Reply #16 on: 18 February 2018, 17:03:59 »
Only if the brakes aren't in good shape....    ...as I believe Mr Wood found out once.
If you've come off the motorway, your brakes wouldn't have had too much of a hammering for a while, so should be cool. There are 6 roundabouts (of sorts), 3 in quick succession, then about a 3 mile section to allow them to cool, and another 3 at 1 mile intervals.
« Reply #17 on: 18 February 2018, 17:08:32 »
That is my daily commute, and nowadays you will not really get above 35mph, due to the retards too inept to attempt to approach the speed limit...   ...and they straightened that road out a lot in the 1990s.
Do you remember which roundabout?  I hit one myself about a dozen years ago, when I managed to overtake the bike I was riding ::)
Vega
  • The Netherlands
    • Omega Saloon 3.2
« Reply #18 on: 18 February 2018, 17:29:02 »
This subject always really puzzles me. Factory omega brakes are really good.
No there not.
I just need something that looks massive basically  ;D
I’ve bought some so hopefully have them for next weekend and trial fit
Like what Doctor Gollum said fit the Pontiac 04 (Holden) brakes, direct fit and uses the standard rotor.
Need larger brake line.
15" rim will also fit
« Reply #19 on: 18 February 2018, 22:17:31 »
Fit '04 Pontiac GTO/Base Monaro calipers with Monaro front brake hoses :y
I thought the general opinion were these did not perform as well as perhaps they look they should?
Possibly the case with a blown V8 under the bonnet ::)
« Reply #20 on: 18 February 2018, 22:24:41 »
That’s for porsche calipers, I’ve had the 18z calipers on but stupidly sold them and the price has gone up to buy more so looking for a cheaper option
Got 18z's on one of mine  :) but looking for an upgrade that'll fit under 17 inch wheels on he project car.
Disc's are the same diameter and thickness are identical, as are the caliper mounts... Pad area is about 50% extra with two pistons per caliper.
I know everyone keeps saying fit these brakes but I’ve never seen any forsale?
Have you tried looking?  ???
« Reply #21 on: 19 February 2018, 15:18:07 »
To be fair, mine were changed shortly after ::)
zirk
  • Epping Forest
« Reply #22 on: 19 February 2018, 18:36:12 »
Dunno, it was a big green one at the end of a short dual carriageway, I remember going through so many of them they all started to merge into one image after a while, but the one I hit certainly stood out  ;D
Still remember it now really, approaching at high speed then thinking 'break' wheres my brakes gone, Handbrake didnt help much at short notice either  :-[
I knew at the time it wasn't going to end well, as I was only just mentally recovering from rolling my Escort Van on a Potters Bar roundabout exit.  ::)  :D
« Reply #23 on: 19 February 2018, 19:02:22 »
There are no dual carriageways between MK and Buckingham, and beyond Buckingham is only the Tingewick Bypass, but that wasn't built in the 80s.  So I guess you must have still been within the MK limits, so might have been what is now the Bottledump Roundabout...  ...which is almost in the built up area now ;D
zirk
  • Epping Forest
« Reply #24 on: 19 February 2018, 19:48:21 »
Hmm, long time ago, the car was only a few weeks old from new, so when did last shape of the Cav's 3 come out, around 88 / 89 of of the top of my head, plus Im seem to remember the guy Peter, who was doing a lot of Rolling Roads tests on my Cav at the time, think it was called Detection Teckniques or something was moving into the new Superchips re Badge era.
Could have been single Track as I got closer to Buckingham, but fairly sure they started as Dual ones before that.  :-\
106pete
  • Plymouth
    • Omega 3.0 elite
« Reply #25 on: 22 February 2018, 16:51:14 »
To answer my own question NO they don’t fine  :o I’ll do some proper trial fitting this weekend see if a adaptor plate can be used.
Plan b, will Saab 9-5 hubs fit the Omega? Yes they are fwd so a cv joint would have to be bolted in and stopping the bearing from falling apart.
« Reply #26 on: 22 February 2018, 17:57:22 »
Answered your own question there ::)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #27 on: 22 February 2018, 18:53:15 »
Could you make that any more complicated?  :o
I wouldn't go to the hassle of adapters to gain such a small increase in disc size. If you're going to do it, fit the biggest discs that you can get a caliper on, under your wheels.
Fitting a bigger caliper to increase the pad size without increasing the disc size is a total waste of effort.
106pete
  • Plymouth
    • Omega 3.0 elite
« Reply #28 on: 22 February 2018, 19:15:40 »
The disc is pretty large tbh buddy, I had 350mm with the Porsche 18z calipers and you couldn’t go much bigger behind the 18” wheels.
Custom disc can cost a fortune so this is the most sensible way of doin it, plus making adaptors will cost nothing to me in work  ;)
106pete
  • Plymouth
    • Omega 3.0 elite
« Reply #29 on: 24 February 2018, 17:32:52 »
I don’t think these brakes are goin to be fitted, the offset is pretty much perfect but bolt holes are way out meaning I can’t just make a straight adaptor  :'(
Follow the link for a terrible picture showing the fit
http://i35.photobucket.com/albums/d177/106pete/omega/ACAAA398-DB17-43A5-BB8C-ECB9B2C47C9A_zpsfq1ingqd.jpg
Pages: 1 [2] 3  All   Go Up
