Author Topic: Heat Exchanger Part numbers  (Read 1696 times)
MeanGene
  • California
    • 98 Catera 3.0 v6
« on: 17 February 2018, 21:03:15 »
Wanted to check the heat exchanger on a 1998 Catera and want to replace the o-rings and seals.  I ordered 4 GM part number 11076852 and 4 90409175 seals.  The 90409175 are metal washers or seals and fit fine on the oil lines going to the top of the heat exchanger plate.  However, the 11076852 o-rings do not fit the collant bridge.  What is the correct part numbers for the washer/seals go to the water coolant bridge?
annihilator
  • Wirral
    • Omega Tourer V6
Re: Heat Exchanger Part numbers
« Reply #1 on: 17 February 2018, 21:45:50 »
4x 12992647 COOLER BRIDGE SEAL
John  :y
