Author Topic: ABS and TC light came on, different tire size?  (Read 6968 times)
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« on: 25 March 2018, 06:41:46 »
After just a few hundred meters the ABS and TC light came on.
I read elsewhere on this forum that different tire sizes can cause this. I have 245/35X18 profile in front and 245/45X18 profile in the rear.
I guess this is the cause of the lights coming on. Is there a way to fix this or do I have to buy new tires for the rear. Reason for the difference is that the 45 profile are to tall for the front and hits the struts spring pocket.
Thanks
Jan Suhr
Stockholm, Sweden
www.protouring.se
Re: ABS and TC light came on, different tire size?
« Reply #1 on: 25 March 2018, 08:03:39 »
245/40/18s all round on Omega 18" wheels... 235/40/18 also acceptable
Jan Suhr
  • Nyköping, Sweden
« Reply #2 on: 25 March 2018, 08:38:41 »
Well I'll check with a set of 17" wheels I have to see if the ABS light comes on with them or not. Then I will get 2 new tires so I have the same all around.
Then I have to find some one who will buy 4 brand new tires, the ones that don't fit  :-\
Jan Suhr
Stockholm, Sweden
www.protouring.se
« Reply #3 on: 25 March 2018, 11:17:56 »
Had you just had the tyres replaced? If so, this can happen, and takes about half a mile to learn the new tyres. Proper learning procedure is in the glovebox handbook.
If the tyres have been on for a while (more than a few miles), then you have a fault.  Did the speedo die at the same time?
« Reply #4 on: 25 March 2018, 11:21:05 »
Vauxhall do not state any size for 18", as Vauxhall never provided any 18" rims.
Even 235/40/18 tyres can rub the strut or wheelarch (depending on camber settings), depending on their shape, such as the god awful GY F1 Assym2
Jan Suhr
  • Nyköping, Sweden
« Reply #5 on: 25 March 2018, 13:18:07 »
Yes the tires and wheels are new and never driven on before. Drove it yesterday a few kilometers to get the paint polished. So I guess it is just a matter of different diameter between front and rear.
Car has only gone 170.000km.
Thanks
Jan Suhr
Stockholm, Sweden
www.protouring.se
« Reply #6 on: 25 March 2018, 14:45:19 »
In that case, it would have sorted itself out by now :y
You may get similar if/when you change tyres again, just while ABS ECU learns the new rolling diameter of each tyre.
Jan Suhr
  • Nyköping, Sweden
« Reply #7 on: 25 March 2018, 14:48:05 »
Thanks you saved me €300 on two new tires  :)
Jan Suhr
Stockholm, Sweden
www.protouring.se
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #8 on: 25 March 2018, 15:42:36 »
Oooh, that I didnt know  :o
Is that All Omegas ? or just the Facelift Model ?
« Reply #9 on: 25 March 2018, 16:02:40 »
Certainly all post 98, but suspect all
neil74
  • newport
    • 2.6 elite estate.
« Reply #10 on: 25 March 2018, 16:13:40 »
My ABS TC lights and the speedo work and don't work whenever they feel like it. and the steering has moods on it when it gets really difficult to steer but after I leave it a while it normally comes back to normal..
« Reply #11 on: 25 March 2018, 16:23:28 »
Well known problem, there are a couple of places that will repair the ECU for you .. :)
« Reply #12 on: 25 March 2018, 17:15:58 »
If yours is post 98, that does sound like a classic ABS ECU failure.
Either replace for known good (from same engine/gearbox combo in order to avoid Tech2 requirements), or send off for repair.
If pre 98, get the codes read on the engine, gearbox and ABS.
neil74
  • newport
    • 2.6 elite estate.
« Reply #13 on: 25 March 2018, 19:13:30 »
Can someone give me a rough idea what it would cost to repair it?.
« Reply #14 on: 25 March 2018, 19:40:35 »
Its a few years back now .. like about 12 !! Mine was done by BBA Reman and cost £130 with a 2 year warranty ... no doubt the price has changed since then !!
BBA Reman site ...
http://www.bba-reman.com/gb/index.aspx
might be worth giving them a ring for a price update
