Author Topic: MAF sensor no signal  (Read 4342 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 26 March 2018, 16:53:23 »
Preparing X807, a 2.2 petrol manual, for its MOT. I have changed the catalyst, which I presumed would get rid of the 0420 fault code. I cancelled all fault codes, but reading live data there was no information from the MAF sensor. I swopped MAF sensors with my other 2.2, then I got data from the MAF sensor, but it read 17Kg/h, 1.00 volts, varying. Air fuel ratio sensor 1 read lean, so did air fuel ratio sensor 2. O2 sensor loop remained open.
How should I proceed?
Re: MAF sensor no signal
« Reply #1 on: 26 March 2018, 16:57:54 »
Was the car up to temperature when you checked the live data?
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 26 March 2018, 17:50:20 »
Yes
terry paget
    • 3 Astras 2 Vectra
« Reply #3 on: 26 March 2018, 20:15:38 »
On my V6 Omegas the lambda sensors flip rich-lean-rich-lean about very second. I expected the 2.2 would behave similarly. I suspect the MAF sensor or one of the lambda sensors.
Would it help to get live data from my other 2.2? With its original MAF sensor and the MAF sensor from X807?
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 27 March 2018, 19:00:03 »
I swopped the MAF sensors between my 2 2.2s. Then I got data from the MAF sensor, but it did not change the behaviour of the first lambda sensor, it still did not cause the gases to vary lean-rich-lean-rich. I put it back in the other 2.2, and then it did indeed record lean-rich-lean-rich.
I conclude I need a new MAF sensor and a new lambda sensor.
PHEASANT PLUCKER
  • WIRRAL
« Reply #5 on: 27 March 2018, 19:19:01 »
I’m selling one from a late model Desmond, if interested.
Check out parts for sale section.  :) :) :)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #6 on: 27 March 2018, 19:22:50 »
Is the Maf the same as a 3.0L, if so I've a couple here £15 posted.
Hoof'land storeman.
« Reply #7 on: 27 March 2018, 19:25:34 »
No, sadly not.
biggriffin
« Reply #8 on: 27 March 2018, 19:27:09 »
No, sadly not.
Ar well.
Hoof'land storeman.
terry paget
    • 3 Astras 2 Vectra
« Reply #9 on: 28 March 2018, 10:16:56 »
PM sent
PHEASANT PLUCKER
  • WIRRAL
« Reply #10 on: 28 March 2018, 11:24:15 »
And replied  :) :) :)
terry paget
    • 3 Astras 2 Vectra
« Reply #11 on: 28 March 2018, 13:09:50 »
