Author Topic: Mondeo Cambelt Change  (Read 9912 times)
« on: 06 April 2018, 11:34:56 »
My Ford Mondeo 2.2 TDCi is due a new cambelt and recently my local garage told me it would cost about £250-£350.
The other day I saw an advert for a website that gets quotes for repairs servicing etc, so I thought nothing ventured nothing gained etc and popped in the details of my car and the work required.  :y
I've had one quote back..... from Halfords Autocentres......     £530.91!!  :o :o :o  I don't think so!  ;D
www.MyCarNeedsA.com
Re: Mondeo Cambelt Change
« Reply #1 on: 06 April 2018, 11:51:38 »
My Tata and the mighty Signum both come with a chain. :)......as does the  Corsa.
« Last Edit: 06 April 2018, 11:53:23 by Field Marshal Dr. Opti »
deviator
  • Chesterfield
« Reply #2 on: 06 April 2018, 11:59:26 »
It's nice to see they provide you with towing equipment as standard.  ;)
« Reply #3 on: 06 April 2018, 11:59:41 »
Why do manufactures use a belt that needs to be 'expensively replaced' every forty thousand miles when a chain 'should' last the life of the car?
« Reply #4 on: 06 April 2018, 12:24:57 »
Modern vauxhalls state 100,000 miles or ten years. People on here will no doubt say that they wouldn't wait that long, but I never keep a car long enough to find out.
« Reply #5 on: 06 April 2018, 12:34:37 »
The Mondeo is 10 years/125,000 miles.  It's an 08 plate and has done about 123500 miles.  :)
So I'm OK for a few months/miles until it self destructs!   ;D
« Reply #6 on: 06 April 2018, 12:40:35 »
.. because a chain isn't compatible with telling people it'll do elevently million miles between oil changes, as they do. ;)
« Reply #7 on: 06 April 2018, 12:42:32 »
If memory serves Vauxhall originally claimed 80,000 miles between cambelt changes for he Omega, which they later revised to 40,000 miles.
« Reply #8 on: 06 April 2018, 12:46:12 »
Yes....oil changes every fifty million miles as prescribed by some manufactures can lead to problems.
Service intervals on cars from the sixties and seventies was often as low as every 3000 miles.
« Reply #9 on: 06 April 2018, 12:52:35 »
Back in the days when a car with 60,000 miles was a high miler!  ::)  :)
« Reply #10 on: 06 April 2018, 12:54:32 »
I think that cars today 'go out of tune' far more slowly than cars of yesteryear.
Carbs have gone.......as have points which would wear and change the timing. I remember seeing the air filter from a Cortina 2000 GXL MK3.
The car was returning about 14 MPG and the filter which was as black as Obama's arse had never been changed. The points were black and pitted, and the plugs which were supposed to be changed each year/12000 miles were wet and black.
Couldn't get it to rev above 3500 RPM. ;D
« Reply #11 on: 06 April 2018, 12:56:28 »
Back in the days when a car with 60,000 miles was a high miler::)  :)
Yep.....a rebore and oversize pistons was quite common on cars at that mileage or less.
TD
  • Swindon
    • Nowt!
« Reply #12 on: 06 April 2018, 12:56:32 »
As my mondeo did at 150k ....  ::)
« Reply #13 on: 06 April 2018, 13:27:34 »
I remember going with a mate to buy a Chevette.  ::) It was in reasonable condition but the engine was as rough as a bear's @rse and the owner clearly clueless. We took a punt on the fact that it just needed some TLC.
I drove it home and it was barely drivable.
We thought we'd go over everything to give it a good service. On removing the rocker cover to adjust the tappets, we couldn't find any. Just a mass of black jelly that wobbled a bit when you started the engine. ;D
The air filter had totally clogged with oil from the breathers, the points were barely opening at all and chunks kept plopping out of the drain plug when we drained the oil.
A new set of filters, plugs, points, oil and coolant change, check the timing and adjust the mixture and it drove like it had just come out of the factory. :y
deviator
  • Chesterfield
« Reply #14 on: 06 April 2018, 13:35:35 »
That bad?  ::)
