Author Topic: egr valve  (Read 2127 times)
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
egr valve
« on: 23 April 2018, 08:01:38 »
Do these do a "self clean" on the 3L V6? Reason for asking is I put the battery back on mine yesterday[I'd took it off to charge it]started the car and let it run for a short while[didn't drive it anywhere]while checking other stuff a few seconds after turning it off there was a noise I can only describe as a Brrrrrr sound for a second or two.So I started car again and on turning it back off it did the same.I don't recall hearing this noise before,but I do know that although it's a different sound and a totally different vehicle/engine that Transits do a self clean of the egr valve and just wondered if this was the same or what else it could be.Rev counter still didn't work[although the needle quivered when I turned ignition on all the warning lights came on/went off as they should and fuel temp gauge worked,but that's a separate issue isn't it?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: egr valve
« Reply #1 on: 23 April 2018, 08:03:19 »
Just blank it off.. no more problems, doesn't affect mot..
Hoof'land storeman.
Re: egr valve
« Reply #2 on: 23 April 2018, 08:30:09 »
Self levelling pump :-\
biggriffin
Re: egr valve
« Reply #3 on: 23 April 2018, 09:48:41 »
Ar yes the wurring noise, yup self leveling pump.
Hoof'land storeman.
BazaJT
Re: egr valve
« Reply #4 on: 23 April 2018, 20:29:18 »
Ah,ok fair enough.Possibly really only reason I heard it on this occasion-as said I don't recall hearing it before-was because I had drivers door open and bonnet also.Hopefully that's one thing less to put right then!
