Author Topic: Misfire  (Read 3571 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Misfire
« on: 27 April 2018, 12:06:29 »
Had a misfire a low revs yesterday. Pedal trick today gives me 0300 - random misfire, and 0304 - misfire #4.
Removed the coil pack and sure enough, there is water in the wells, and the pack has cracks. Has anyone got a part number for the 2-4-6 pack please?
Shackeng
  • Ramsbury
Re: Misfire
« Reply #1 on: 27 April 2018, 12:15:04 »
I've located it by the Bosch number. BOSCH IGNITION COIL 0 221 503 027 . £58 odd online which is not bad I suppose. I'm hoping someone may have a good one from a breaker. :y
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
Re: Misfire
« Reply #2 on: 27 April 2018, 13:01:37 »
I've fixed a few 4 ones just putting it in oven and drying out. And then seal the cracks with some sealing glue. All seamed fine after. Just make sure it's cold when sealing. Not had a problem with one on Mig or vectra all in all cost £1.25p for the sealer.
Shackeng
  • Ramsbury
Re: Misfire
« Reply #3 on: 27 April 2018, 13:06:40 »
Cheers Chas, I have thought of that, and  it would certainly clean up alright, but there is some delamination of the metalwork and as this car is in such good condition, I prefer to replace this part with a good one.  I've checked the 135 pack and it is fine.:y
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: Misfire
« Reply #4 on: 27 April 2018, 13:08:40 »
Gas oven? What regulo number? I guess a microwave oven would not be advisable?
Ron.
Chazza12
  • south yorkshire
Re: Misfire
« Reply #5 on: 27 April 2018, 13:21:12 »
mine is gas but had it at 180f  gas mark 2 or 3 for around 5-10 min but keep an eye on it.
Bigron
  • Witham, Essex
Re: Misfire
« Reply #6 on: 27 April 2018, 13:38:22 »
180 degrees frankenstein, not centipede?
Ron.
Shackeng
  • Ramsbury
Re: Misfire
« Reply #7 on: 27 April 2018, 13:43:02 »
This is the delamination of no 6 connector
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Misfire
« Reply #8 on: 27 April 2018, 13:57:56 »
Yeah that's goosed ! :o
Re: Misfire
« Reply #9 on: 27 April 2018, 15:43:54 »
Remember to solve the root cause of the problem too - likely a leak from the scuttle panel if it's been parked outside in the rain. You probably need to seal the area where the scuttle meets the pollen filter housing on the bulkhead. :y
EDIT: While you're at it check the windscreen seal is secure and seal the wiper spindle hole above the other bank too.
Shackeng
  • Ramsbury
Re: Misfire
« Reply #10 on: 27 April 2018, 15:51:44 »
 :y :y :y
Shackeng
  • Ramsbury
Re: Misfire
« Reply #11 on: 27 April 2018, 16:12:16 »
The soundproofing is completely dry, so I am a bit puzzled. :-\
Re: Misfire
« Reply #12 on: 27 April 2018, 16:33:15 »
It probably hasn't come from behind via the windscreen seal, then, but it must have got past the scuttle panel somewhere.
Shackeng
  • Ramsbury
Re: Misfire
« Reply #13 on: 27 April 2018, 16:40:31 »
Well it has been outside most of its life, so one can expect a little water getting in. However, I suspect I may have damage the pack removing it when I did the plugs years ago, being unaware at the time of the removal bolt method.:y
