Author Topic: gear stick and handbrake gaiter  (Read 2470 times)
ChrisPee
  • Kent
    • Omega Select estate
« on: 02 May 2018, 14:39:55 »
I was just wondeting if any members have purchased either of these from Ebay tgat actually fitted? I bought one amd it was pretty poor. I need a set for an early manual. Also, could amyone tell me if the pattern of the leather seats is the same from early elite to late please?
Thank you. Chris.
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: gear stick and handbrake gaiter
« Reply #1 on: 02 May 2018, 15:11:29 »
They need a little trimming with a razor blade, and then gluing into place. Mine took less than an hour to fit both. Some of that included making coffee. I suspect that they supply the same gear lever gaiter for both transmissions.
It's one of the easier jobs I've done on the car.
« Last Edit: 02 May 2018, 15:14:24 by Nick W »
ChrisPee
  • Kent
« Reply #2 on: 02 May 2018, 15:31:09 »
Can you remember the seller Nick? The one I bought was like trying to fit a babygrow on giant haystacks. A bit of trimming and glueing is fine by me. The one I had wasn't even close.
  • Chatham, Kent
« Reply #3 on: 02 May 2018, 20:43:22 »
I bought THESE
Which look like this:
and
The tops are secured with a cable tie which looks shit, so I quickly replaced them with lockwire that isn't visible. some thin cord would do just as well.
A nice easy job that smartens up an obvious scruffy area.
ChrisPee
  • Kent
« Reply #4 on: 03 May 2018, 08:38:56 »
Thank you, much appreciated.
