Britta water filters
Started by tigers_gonads, 03 May 2018, 15:12:12
Shackeng
Quote from: tigers_gonads on 03 May 2018, 19:20:06
Quote from: Shackeng on 03 May 2018, 19:19:12
Quote from: dave the builder on 03 May 2018, 18:19:29
just fit a drinking tap with in-line filter under the sink ,much cheaper , kits are £20+
fill the kettle from that  :y
carbon filters remove chlorine and chloranine so water should not be stored (in jugs in the fridge etc ),for any length of time.
plus you use more electricary to boil fridge stored water (it's colder ,unless your fridge is u/s)
^^^This. I use Pureflo. Replace the granules and carbon about every 6 months. :y
How much does the granules cost shack ?
http://www.pureflo.co.uk/water-filter-kits/resin-refill
Currently £17.50, last for 6 months. :y
dave the builder
I run our's through a 5 micron in-line sediment filter first(gets rid of silt dirt etc, you'd be surprised  :o )
,then via in-line activated carbon filter (removes chemicals )
good enough for us to drink  :y
the Koi are much more fussy about their water quality though  ;D
Rods2
Quote from: Field Marshal Dr. Opti on 03 May 2018, 16:43:18
Water filters....that's what Tony Blair and the metropolitan elite use. ;)
The great unwashed proletariat such as myself take the water as it comes. ::)
I'm sure the chewy bits from your well keep you in fine fettle m'Lud, especially winding up 50m of cable with a 10l bucket on the end of it several times a day. :y :y :y The hole in the ground for the outside toilet with its sheets of torn up newspaper must save you having to keep filling the new fangled indoor flush system and jogging once a week to your local market for a roll of Bronco. :o :o :o There might even be one or two third world people jealous of such luxury living. ;D ;D ;D
Bigron
Bronco! Our school bogs used that, with the admonition to use both sides of the paper!!! :(
Ron
ronnyd
Can,t beat a good old roll of Izal. Didn,t wipe it, just spread it around a bit. :D
Quote from: ronnyd on 03 May 2018, 22:20:56
and you can draw on it if inspiration strikes at an empty moment ::)
Try not to use a brown pencil!
Izal was simply old-fashioned grease proof paper given a fancy name. Nothing would stick to it, especially shit, which made it 'unfit for purpose'...... :(
