Author Topic: Merc DIY Service  (Read 10431 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Merc DIY Service
« on: 20 May 2018, 06:20:57 »
Quotes by Indie's approx. £280, didn't bother to get a quote from the main dealer.
DIY:-
Air filter - piece of cake
Cabin filter - a bit fidley, but will be easier next time, now I know what I'm doing.
Oil Filter - piece of cake.
Oil Change - piece of cake with a pump.
Cost inc. oil and parts approx. £70
Probably one of the easiest cars I've worked on to do a basic service, everything was so accessible :y
Even easier than my 2.2 Omega.
To do ATF change, not inc. in Indie quotes.
Brake fluid change, not inc. in Indie quotes
Fuel filter, not inc in Indie quotes.
« Last Edit: 20 May 2018, 07:25:09 by Auto Addict »
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Merc DIY Service
« Reply #1 on: 20 May 2018, 06:35:41 »
How do you guys clean out the pump after use?
I like red cars
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #2 on: 20 May 2018, 07:29:31 »
Just had a B service done on my Merc which was £291. All of the above plus a brake fluid change and a fob battery..
Labour 2hrs £118 and parts £124 (+ vat) Done by a mobile Merc indy.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #3 on: 20 May 2018, 08:31:46 »
As I only use mine to pump out, its not an issue. :y
2boxerdogs
« Reply #4 on: 20 May 2018, 13:37:17 »
Had mine done at MB at Boston last time do a special deal for older Mercs & also MB owners club members even let me supply my own oil cost me about £90 or thereabouts also received printed health check.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #5 on: 20 May 2018, 13:46:27 »
Do modern Mercs still have the oil filter at the top of the engine? My w201 does and my w202 also did.
It makes me wonder why all the others don't design their engines the same way.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #6 on: 20 May 2018, 14:38:20 »
Same as the D5 engine.
32mm socket on the plastic housing, then unclip the paper filter and drop it straight in the box the new one came in, change the big rubber o-ring on the housing and reassemble. A 2min job (that actually takes 2mins), no mess and no farting about with filter wrenches.  :y
Shackeng
  • Ramsbury
« Reply #7 on: 20 May 2018, 15:14:45 »
Same as the Omega TD BMW engine. :y
« Reply #8 on: 20 May 2018, 15:18:12 »
The same as every engine should be.
« Reply #9 on: 21 May 2018, 13:52:23 »
The thing is, every engine modern engine is going to have its oil pump at or below crankshaft level, so plumbing in a run up to a top mounted filter and then back to the oil galleries (crankshaft level, again) is a ballache. Plus, most modern cars are designed to be serviced from below on a ramp, as that's how you have to do most of the other servicing tasks, anyway.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #10 on: 21 May 2018, 14:02:39 »
DIY:-
Do modern automobile's not have sump plugs. ;)
Hoof'land storeman.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #11 on: 21 May 2018, 14:35:32 »
DIY:-
Yes, but as I said, I used a pump.
Too old now to crawl underneath. :(
I like red cars
« Reply #12 on: 21 May 2018, 18:33:37 »
The instructions for mine say to run fresh oil through it to clean.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #13 on: 21 May 2018, 20:40:29 »
That seems like a waste of fresh oil. :-\
I like red cars
« Reply #14 on: 21 May 2018, 20:41:23 »
If you're only going to use it for draining dirty oil, why clean it?
