Author Topic: I can do without this shit ............  (Read 6623 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 22 May 2018, 18:42:35 »
Left the lad to stick one of the front wheels on while I popped in for a dump  ::)
Came outside 10 minutes later to find him using a impact gun to start and tighten the wheel bolts  >:(
Now I have 3 which are about 400Nm and 2 which he had started cross threaded and carried on banging away with the gun until they are in  >:(
Can I take it that the bolts will strip before the hub ?
Also if I can get them out, what size tap and die do I need to see if I can save the day ?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: I can do without this shit ............
« Reply #1 on: 22 May 2018, 18:45:07 »
12x1.50 rings a bell, bet I'm wrong tho.
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #2 on: 22 May 2018, 19:23:21 »
That's what they are. But it's a non-perfered size so you'll probably have to order a tap.
« Reply #3 on: 22 May 2018, 21:15:51 »
If it's any consolation my lad did exactly the same thing on his car despite me telling him not to  >:(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 22 May 2018, 21:19:12 »
What's that mean Nick ?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #5 on: 22 May 2018, 21:21:44 »
Oh it wouldn't be too bad if it was his car  ;D
At least I could rip the piss out of him for a while ............. well until I had to fix it for him that is  ;D
« Reply #6 on: 22 May 2018, 21:24:07 »
Might have a spare, new, unbranded hub here...
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #7 on: 22 May 2018, 21:27:46 »
IF I need it, how quick could you get it in the post Al ?
I'd rather not if I can get away with it because knowing me (just like the other side I did a couple of years ago) i'll smash the abs sensor too  :'(
« Last Edit: 22 May 2018, 21:29:57 by tigers_gonads »
« Reply #8 on: 22 May 2018, 21:49:11 »
A day or so, will confirm I actually have it when I get home :y
  • Chatham, Kent
« Reply #9 on: 22 May 2018, 21:59:58 »
That's what they are. But it's a non-prefered size so you'll probably have to order a tap.
Metric threads are normally the coarse pitch, which would be 1.75mm for an M12 fastener. For some reason cars are littered with M12x1.5 threads, which most suppliers have to order in. That includes nuts, bolts, taps and dies.
« Reply #10 on: 22 May 2018, 22:49:33 »
Despite having a bucket full of various taps & dies, I'd to borrow the metric fine from a local garage to sort  out my lads mess.
« Reply #11 on: 22 May 2018, 23:02:49 »
Sounds like the Kwik Fit recruitment department have nothing to worry about. ;D
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #12 on: 23 May 2018, 10:34:09 »
Yup  ;D ;D
He is a very intelligent lad (if lacking in confidence) but absolutely sweet f all mechanical aptitude sadly  :(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #13 on: 23 May 2018, 10:36:55 »
Question about these tap and dies .............. I have both a tap and die in M12 x 1.75.
You lot say the omega is a M12 x 1.5 ?
What / where is the 0.25 difference ?
Is it the gap between the threads ?
  • Chatham, Kent
« Reply #14 on: 23 May 2018, 10:43:20 »
Yes. The 1.5 is the distance between two thread crests, measured in mm. Your tap and die are 1.75 because that is the usual M12 pitch.
