Pages: 1 [2] 3  All   Go Down
Author Topic: Jaguar front splitters.  (Read 10146 times)
Re: Jaguar front splitters.
« Reply #15 on: 28 May 2018, 15:55:08 »
Tiger seal.  :y.............as long as you don't intend removing it again.  ;)
I expect it will need to come off again.
Isn't a Tiger seal a large lump of blubber that lies on the beach all day?
I don't think you should write about TB like that :o
An hour in the sack with the girl of his dreams (Shami. C) would remedy that. :)
300 calories a time. Six times a day. :)
« Reply #16 on: 28 May 2018, 16:01:46 »
The jaguar forum suggest Evostick.
It's stringy as f*uck but you can get it off again.
Yep, that would fit the bill.
« Reply #17 on: 28 May 2018, 17:19:08 »
It'd be 350 calories. She'd have to catch him first. ;D
« Reply #18 on: 28 May 2018, 18:13:11 »
Black Sikaflex :y
Good for 150 mph and can be removed with heat and white spirit...
« Reply #19 on: 28 May 2018, 18:51:58 »
Black Sikaflex :y
Don't think I'd want to put heat anywhere near the front end of my jag.  :o
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #20 on: 28 May 2018, 20:13:06 »
It doesn't need heat (Nor does Tiger seal). It needs a thin / sharp implement, like a wallpaper scraper tapping along the join to cut through it.
An omega boot spoiler takes about 15 minutes to remove by this method.  ;)
« Reply #21 on: 29 May 2018, 16:28:18 »
Tiger Seal has been mentioned on the Jaguar forum also. ....along with Sikaflex. They say it will be a bastard to remove the trim again once this stuff has 'welded' the splitter to the bumper.
Some suggest 3M VBH double sided tape.
« Last Edit: 29 May 2018, 16:41:09 by Field Marshal Dr. Opti »
« Reply #22 on: 29 May 2018, 17:07:09 »
Number plate tape?
« Reply #23 on: 29 May 2018, 17:57:54 »
Evostick still sounds best to me. And you can get off your head while doing it.
« Reply #24 on: 29 May 2018, 18:33:03 »
Back in the good old days we used butane lighter fuel. :)
« Reply #25 on: 29 May 2018, 18:33:33 »
Gripfill is good, flexible and cheap.  :y
You can get off your head on that too!  ;D
« Reply #26 on: 30 May 2018, 09:04:55 »
I can certainly tell you that 3M trim tape sticks like sh*t to a blanket.
Not that I'd know about the latter.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #27 on: 30 May 2018, 16:16:28 »
Not so easy to remove again though? Most things in our house have gripfill in their makeup somewhere down the line. It’s particularly good for attaching skirting board  :y
Opti, just to throw another idea in, double sided glazing tape, it’s a bit like those sticky numberplate pads but comes on a roll. Also cheap and sticks like, um, well as above.
Comes off without too much of a fight too. You can cut it in half with a knife then peel each side off separately.
« Reply #28 on: 30 May 2018, 18:31:21 »
I've only ever known the numberplate stuff to come on a roll, never knew it was available as pads.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #29 on: 30 May 2018, 19:20:52 »
A certain Scouser might be able to answer that. :)
Hoof'land storeman.
Pages: 1 [2] 3  All   Go Up
