Author Topic: Brakes  (Read 8237 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Brakes
« on: 25 May 2018, 14:45:50 »
The front brake pads and callipers are now sorted  :y
Back wheels coming off in morning (weather permitting) to do anything needed then i'm going to push through some new fluid.
Question is .............. what order do I bleed ?
Also, engine off or running ?
Re: Brakes
« Reply #1 on: 25 May 2018, 14:48:47 »
NSR, OSR, NSF, OSF.
And keep the fluid level high or you'll have to do the clutch as well ::)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Brakes
« Reply #2 on: 25 May 2018, 14:50:38 »
NSR, OSR, NSF, OSF.
Yup  :y
Engine on or off ?
Re: Brakes
« Reply #3 on: 25 May 2018, 15:15:18 »
NSR, OSR, NSF, OSF.
Yup  :y
Engine on or off ?
I've always done it engine off.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Brakes
« Reply #4 on: 25 May 2018, 15:32:55 »
Come to think about it, so have I  ::) ;D
Okay, thanks lads  :)
Re: Brakes
« Reply #5 on: 25 May 2018, 15:54:38 »
It doesn't really make any difference when the vehicle has a 4 channel ABS system, any order will work
Re: Brakes
« Reply #6 on: 25 May 2018, 17:38:32 »
Agreed. But IIRC Mr Haynes suggests 2 different orders to bleed depending on age of vehicle ie. 3 or 4 channel ABS.
Re: Brakes
« Reply #7 on: 25 May 2018, 23:01:57 »
As I understand it, you work your way back to the master from the furthest point ;)
Re: Brakes
« Reply #8 on: 25 May 2018, 23:19:46 »
Is that on a 3 or 4 channel ABS system?   ::)
Re: Brakes
« Reply #9 on: 25 May 2018, 23:34:36 »
Worked on every car I have changed the brake fluid on...
And some of those have even had a proper gearbox :P
Re: Brakes
« Reply #10 on: 25 May 2018, 23:43:10 »
2 pedals then .....  ::) ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Brakes
« Reply #11 on: 26 May 2018, 00:10:47 »
it's on everything. Twice around the car is normally enough to get a decent pedal after fitting a new master cylinder or most of the brake pipes.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Brakes
« Reply #12 on: 26 May 2018, 11:07:42 »
IIRC, all mini and facelift omegas have 4 channel ABS.
The pfl cars rear sensor was on the diff so their 3 channel  :-\
So the answer is ...........
Any order
A couple of squirts each nipple
And don't let it drop too far or i'll end up breading the clutch too  ::)
Thanks  :-*
  • Chatham, Kent
Re: Brakes
« Reply #13 on: 26 May 2018, 11:20:41 »
Any order
Thanks  :-*
no, you bleed each nipple until you see plenty of clean, airless fluid. This can take a while if you've fitted a new master cylinder or long brake pipe.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Brakes
« Reply #14 on: 26 May 2018, 11:31:38 »
Any order
Thanks  :-*
Nothings been changed Nick.
The brakes have never been particularly good with a soft pedal.
I had to stand on the brakes last week due to some dickhead on a bike, all in black with no lights pulling across me while doing 40 ish  :-X.
The car stepped sideways for a second until I relesed some brake pressure.
Upto now i've found pads which was half worn and a seized slide on the passenger side  :(
When Serek swapped the slush box for a proper one a couple of years ago, he mentioned that the fluid was shite and needed changing  :(
2 years and 12K miles later, i'm finally getting around to it  :-[
Hopefully fresh fluid in the callipers which hasn't been boiled should get rid of the spongy pedal  :-\
The fluid is probably 155K old too
