Author Topic: Opti LUBE ?  (Read 12787 times)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Opti LUBE ?
« on: 26 May 2018, 11:28:35 »
I need to check / replace my trans fluid
53 plate CDXi 2.6 auto omega
service history is ticked as trans fluid replaced a couple of years ago , BUT anyone can tick a box  :-\
searching TheBoy's fave on-line shopping place ,I came across this
Opti lube clicky   :o ;D
says "ATF GM DEXRON III  " so the right stuff ?  and must be good stuff if Field Marshal Dr. Opti makes it ?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Opti LUBE ?
« Reply #1 on: 26 May 2018, 13:26:11 »
Really, ask Him what Gearbox Oil is for then.  ;D
Re: Opti LUBE ?
« Reply #2 on: 26 May 2018, 13:27:23 »
Are you musical Dave?
Re: Opti LUBE ?
« Reply #3 on: 26 May 2018, 13:31:47 »
If he's to be believed our Lord Opti is in no need of artificial lube products, as his rides self lube at the very sight of his big.......medallion! ;)  :P  ;D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Opti LUBE ?
« Reply #4 on: 26 May 2018, 13:35:04 »
Tone def  :y I can't even play the tri-angle  :y
is this relevant to changing my gearbox fluid  :-\
do I have to sing a song or summat ,when removing the sumps ??  :-\
I assume he put instructions on the tubs ?
zirk
  • Epping Forest
Re: Opti LUBE ?
« Reply #5 on: 26 May 2018, 13:41:01 »
Remove Gear Stick Gator, Spray thoroughly into Big Hole, refit Gator and your good to go for another 100k.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Opti LUBE ?
« Reply #6 on: 26 May 2018, 13:45:48 »
But mines one of them daft ,'change the gears for you' contraptions with a pedal missing  :'(
Re: Opti LUBE ?
« Reply #7 on: 26 May 2018, 14:01:59 »
Your linky goes to an ebay page selling stands for sheet music.  ::)  ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Opti LUBE ?
« Reply #8 on: 26 May 2018, 14:04:18 »
new link clicky
Sorry , my bad  :-[
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Opti LUBE ?
« Reply #9 on: 26 May 2018, 14:25:01 »
That original link is a "wank-stand" for my brother to hold his jaz mag  :y  ;D
he was being mean to me on friend face  :y
Re: Opti LUBE ?
« Reply #10 on: 26 May 2018, 16:42:53 »
I didn't think anyone bought jazz mags anymore.  :-\
The snowflake generation of young lads will never know the joy of swapping a mag and finding the pages stuck together!  ;D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Opti LUBE ?
« Reply #11 on: 26 May 2018, 17:15:34 »
probably still sell them up north ( Doncaster and beyond ) where there's no internet  :y
Hence my brother's need for a 'jazz music stand' to keep reading material out of the firing line of the 'instrument' :y
anyway ......
OPTI LUBE , yay or nay  :-\
2 tubs would give me enough spare for spillage if the box needs 8 ltr
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Opti LUBE ?
« Reply #12 on: 26 May 2018, 19:02:07 »
Hoof'land storeman.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Opti LUBE ?
« Reply #13 on: 30 May 2018, 17:39:23 »
I use this
https://www.mil-specproducts.com/products/SHELL-DONAX-TX-OIL
not finding it on ebay or local supplier ,my postman is too lazy to deliver a 205L drum  ;D
I looked further into dexron 3 or better
found semi synthetic at ucp for £21 for 5L
https://www.ebay.co.uk/itm/Triple-QX-ATF-Dexron-III-5-Litre-5L-Automatic-Transmission-Fluid-DII/352223598451?hash=item5202299773
or fully synthetic dexron VI made by exol for £24.45 per 5 L
https://www.ebay.co.uk/itm/351610927313
which reading the spec is backwards comparable ,better then dexron III
So I'm thinking of getting 2 of those for the devils gremlins (inside the auto gearbox) to keep them happy  :-\
also found "trade club" 10w40 semi @ £42 delivered , is that the stuff everyone uses ?
https://www.ebay.co.uk/itm/20LTR-DRUM-10W40-ENGINE-OIL-new-VAUXHALL-GENUINE-SEMI-SYNTHETIC-PETROL-DIESEL/253266803486?epid=10010414960&hash=item3af7e0bb1e:g:vh4AAOSwGWNUVLoL
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Opti LUBE ?
« Reply #14 on: 30 May 2018, 17:42:33 »
^^^ Its what I use. :y
