Author Topic: Scuttle removgal  (Read 6167 times)
gbh
  • forest of dean
    • omega cdx 2.6
Scuttle removgal
« on: 29 May 2018, 15:11:25 »
Had a misfire on the V6 and it was water in plug well 2 so trying to remove scuttle but first the wipers aNd they won't budge. Tried rocking and hot water,WD40,hammer but it won't have it any suggestions or tool I could make or cheaply buy?
deviator
  • Chesterfield
Re: Scuttle removgal
« Reply #1 on: 29 May 2018, 15:22:39 »
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #2 on: 29 May 2018, 15:36:09 »
Or one of THESE
I have one, but have never needed to use it on wipers. They've always come off by folding them, and jiggling.
deviator
  • Chesterfield
« Reply #3 on: 29 May 2018, 15:41:25 »
Or one of THESE
A CAD drawing? How does that help? I can't even work out how it would help if it was an actual item.
  • Chatham, Kent
« Reply #4 on: 29 May 2018, 16:19:23 »
Or one of THESE
wrong link. Bloody computers, you can't trust them ::)
gbh
  • forest of dean
    • omega cdx 2.6
« Reply #5 on: 29 May 2018, 16:28:59 »
I reckon the only thing moving is the body probably been there since new
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #6 on: 29 May 2018, 17:50:18 »
Machine Mart market a tool named Windscreen Wiper Arm Remover, but it's not much good, inclined to bend. I use a two legged puller that came with a Heidelberg GTO print machine, to pull bearings off rollers. The above bearing puller might work, but it's got too many legs.
addy
  • County Durham.  UK
    • 2.6 CD Saloon 2ltr omega
« Reply #7 on: 29 May 2018, 19:54:30 »
Last time I had to remove some stuck arms on a friends car, I used a ball joint tool similar to this, it worked great:- https://www.autozone.com/loan-a-tools/tie-rod-end-puller
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #8 on: 29 May 2018, 22:23:05 »
I have never found the need for any special tool. Once the nut has been removed, some forceful downwards movement on the arm around the area where the spring is located has always worked for me.
« Reply #9 on: 29 May 2018, 22:47:20 »
Loosen nut, fold arm up, grab hinge end of arm and jiggle. Tapping spindle with a ratchet if a shock is required to dislodge it :y
« Reply #10 on: 29 May 2018, 23:00:17 »
That's what I've always done, but removal of my Mercs wiper arm needed a ball joint puller like that linked to by addy
« Last Edit: 29 May 2018, 23:08:10 by Andy B »
gbh
  • forest of dean
    • omega cdx 2.6
Re: Scuttle removal
« Reply #11 on: 29 May 2018, 23:34:03 »
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Scuttle removal
« Reply #12 on: 30 May 2018, 17:46:17 »
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #13 on: 30 May 2018, 17:57:44 »
Yes, I bought one even though I don't need it right now - with a 17-year-old car you never know!
Thanks for the link, gbh.  :y
Ron.
gbh
  • forest of dean
    • omega cdx 2.6
« Reply #14 on: 18 July 2018, 09:41:35 »
Used the tool and it worked a treat,one was a bit tight but using both tool and rocking arm it popped off and after applying sealent no more water problems!!!!!
