Author Topic: windscreen wiper stop parking position  (Read 4118 times)
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
« on: 30 May 2018, 10:37:52 »
HI,,  the windscreen wipers keep parking in the center of the screen instead of at the bottom after washing the windscreen
any ideas
Thankyou
    • 530D M Sport, 330i Coupe
Re: windscreen wiper stop parking position
« Reply #1 on: 30 May 2018, 11:18:14 »
Check the guides, there's a procedure there.
swordfish
  • manchester
« Reply #2 on: 30 May 2018, 11:57:34 »
ok thanks ,, were about is the guide ,,
« Reply #3 on: 30 May 2018, 12:39:31 »
At the top of the page .....Where it says maintenance guides  ;)
http://www.omegaowners.com/forum/index.php?topic=117001.0
addy
  • County Durham.  UK
    • 2.6 CD Saloon 2ltr omega
« Reply #4 on: 30 May 2018, 13:04:49 »
My wifes rear wiper on her estate, does this. When I was looking for a repair I found the following site. Might be of some relevance to someone?  I know it doesn't mention Omega, but they must be nearly the same inside. http://www.vauxhallownersnetwork.co.uk/index.php?threads/astra-how2-to-fix-astra-vectra-zafira-wiper-motor-parking-fault.166111/
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
swordfish
  • manchester
« Reply #5 on: 30 May 2018, 13:30:50 »
ok thankyou all sorted now ,,  :y :y
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« Reply #6 on: 30 May 2018, 17:31:40 »
I had this problem and it seemed to sort itself, only to return a week or so later , i managed to cure problem by changing big yellow relay under bonnet
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
addy
  • County Durham.  UK
« Reply #7 on: 01 June 2018, 15:28:37 »
Hi Swordfish, can you tell us what it was causing the problem, and how you fixed it.
Might give me something I haven't looked at.
Thanks
« Reply #8 on: 01 June 2018, 20:08:16 »
R
Thanks
If you mean the front screen wipers, it's usually as I linked to, caused by wipers being switched on while they're still frozen to the screen.
