Pages: 1 2 [3]  All   Go Down
Author Topic: Gearbox issues  (Read 15723 times)
0 Members and 3 Guests are viewing this topic.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Gearbox issues
« Reply #30 on: 03 July 2018, 20:21:59 »
Gearbox filter can be cleaned and re-used if you wish to do it that way.ABS used to sell a new filter and both sump gaskets at reasonable cost.perhaps worth a PM to KeithABS? I also understand sealant can be used in place of gaskets[?]
New POD
  • Miseryside
    • NEED MV6
Re: Gearbox issues
« Reply #31 on: 03 July 2018, 21:54:25 »
Did you have an "Automatic Gearbox" warning on the MID/GID/CID?
no
New POD
  • Miseryside
    • NEED MV6
New POD
  • Miseryside
    • NEED MV6
Re: Gearbox issues
« Reply #33 on: 04 July 2018, 06:52:16 »
Following my BMW experience, quite possibly a speed sensor/abs* wiring fault.
*not the traditional failure modes.
Box will be stuck in third. I would also wager that it won't change gear manually. Drive it any distance and you'll need a new box regardless.
Interestingly you can also con it back to using all gears by stick it in neutral.   :-[
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Gearbox issues
« Reply #34 on: 04 July 2018, 17:06:06 »
This sounds as though a selector clean may be in order. :y
https://www.omegaowners.com/forum/index.php?topic=90673.msg1155646#msg1155646
New POD
  • Miseryside
    • NEED MV6
Re: Gearbox issues
« Reply #35 on: 04 July 2018, 20:20:56 »
Today I drove From Bradford to Wolverhampton with lots of stop start traffic for the first 35 mins and an ambient temperature of 25 to 26 degrees C and I did not experience the symptoms.
Still, next week I'll change the oil and clean the selector.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Gearbox issues
« Reply #36 on: 04 July 2018, 21:50:37 »
New POD
  • Miseryside
    • NEED MV6
Re: Gearbox issues
« Reply #37 on: 04 July 2018, 22:46:15 »
I had the wishbones replaced in 2016 about 40K ago, but I bought the kit because there is clonking from my drop links and one of the steering arms has a little play in it, and by the time I'd priced them up it was almost as cheap to get the wishbones as well, in the kit.
Pages: 1 2 [3]  All   Go Up
Page created in 0.024 seconds with 16 queries.
