Author Topic: Alternator or battery confusion  (Read 6989 times)
Joe the fish
  • Dorset
    • 2002 Omega 2.2
« on: 04 June 2018, 15:57:53 »
Hi all.
Bit of a strange one, went out yesterday for approx 50milr journey stopped and started three times while the out on the last time clicked like a flat battery after being stopped for less than five minutes. No other signs of battery issues until then. It jumped straight away with no issues and then drove the 50mile trip home without problems. I assumed battery and replaced it with a brand new one. This morning started fine did 20miles to work restarted later for another 10 mike journey then again for a 25mike trip. Again got back in after less than 5 minutes and completely dead. Jumped fine and drove 25 miles back. Now battery completely flat again but will jump first time and drive normally.
I am assuming alternator is putting out charge or I shouldn’t have made any of the trips after jumping but it’s xlearly not charging the battery. So something in the charge circuit?
Battery connection is all good any thoughts on where else to look?
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
Re: Alternator or battery confusion
« Reply #1 on: 04 June 2018, 16:10:17 »
When something similar happened to me it was many years ago in a Ford Cortina.  I was driving along and all power went, with the radio first cutting out, then everything else.  It turned out to be a faulty alternator.
So, if the engine kept running until you parked up, then would not restart after a delay, it sounds to me as though you are losing the charge in the battery that you say is now new.  Something is being "left open" for it to discharge like that, and if it is not the alternator (which I would still check) it is to do with the regulator or a short on a circuit.
Others no doubt will give more specific advise ;)
Joe the fish
  • Dorset
    • 2002 Omega 2.2
« Reply #2 on: 04 June 2018, 16:20:03 »
Thanks I’ll add that to the list of things to check although I can’t think of anything that would drain it on less than five minutes...although I guess it could be draining all day and just got low enough after that particular stop. But would it still drive fine for a prolonged period?
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 04 June 2018, 16:28:41 »
Stop guessing and use a multi meter.
If it shows less than 13.5volts with the engine running, you have an alternator fault. If it's charging correctly, you need to read the forum guide for what to do next.
Alnico Blue
  • Costa del 'Saffend
    • 2001 2.6 CDX estate
« Reply #4 on: 04 June 2018, 16:30:19 »
Do the checks in Kevin Woods  excellent guide on starting/ charging diagnosis which you will find  in the maintenance section under ICE/Electricals  . . .external electrics sub section .  ;)
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
Joe the fish
  • Dorset
    • 2002 Omega 2.2
« Reply #5 on: 04 June 2018, 16:34:02 »
Cheers all,
Yes multi meter would be a wise move but I’m at work racking my brains without one
Guess some diagnosis tonight when I get home
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #6 on: 04 June 2018, 16:36:05 »
I'm assuming that the OP asked because he wasn't sure what to check, so while your advice is sound, it could have been delivered in a more courteous manner, rather than your usual peremptory (ie Why don't you know?) tone.
« Reply #7 on: 04 June 2018, 16:38:10 »
Kevin Woods guide on the subject is fool proof and works on any vehicle  :y
But you will need a multi meter...
Could be a current drain somewhere, but the guide covers this ;)
Joe the fish
  • Dorset
    • 2002 Omega 2.2
« Reply #8 on: 04 June 2018, 16:53:27 »
Thanks all,
Guide read just need to get home and find the multi meter now.
Dont worry no offense taken.
« Reply #9 on: 04 June 2018, 17:11:54 »
As others have suggested, Kevin Wood's guide is the one to follow, as there are 3 likely causes:
Shagged alternator
Shagged batt (despite being new)
Intermittent high drain, eg stuck HRW relay.
The guide will take the guesswork out :)
Now, I'm sure your boss is paying you to work, not sit on internet ;D
« Reply #10 on: 05 June 2018, 08:47:01 »
Hi, pot!  :P ;D
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #11 on: 05 June 2018, 15:07:59 »
I had very similar thing Greenshag checked my alternator output and said it was ok .next day flat battery .Put new alternator on problem gone.
« Reply #12 on: 05 June 2018, 17:41:15 »
Hi, pot!  :P ;D
Nah, I'm a good boy, very rarely touch OOF whilst at work (lack the time), only if I see a load of mod reports coming in :)
Joe the fish
  • Dorset
    • 2002 Omega 2.2
« Reply #13 on: 05 June 2018, 18:54:45 »
Like a good boy I didn’t use works internet but finally got the multi meter on it tonight battery ok. Alternator reading 12.1 - 12.3 regardless of revs and measured direct off terminals at back of alternator. During test volts dropped to 0.4 twice not unconvinced that wasn’t the multimeter but either way suspect alternator so it’s now off and will get dropped into the local test and refurb place tomorrow.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #14 on: 05 June 2018, 19:37:35 »
The voltage even directly at the alternator cannot suddenly drop to 0.4 whilst it has a battery connected to it. By all means have the alternator tested if you realy wish but sounds more like a bad connection somewhere to me.
Page created in 0.026 seconds with 20 queries.
