Author Topic: looking for the HD Donuts 90539049  (Read 4960 times)
Vega
  • The Netherlands
    • Omega Saloon 3.2
« on: 08 June 2018, 14:12:02 »
Anyone knows where I can find these HD donuts 90539049 if they still exists.
I know a few years back they where one eBay but now nowhere to be found.
Re: looking for the HD Donuts 90539049
« Reply #1 on: 08 June 2018, 14:34:06 »
Best bet is...
https://www.summitracing.com/search?keyword=EP1145
With...
https://www.summitracing.com/search?keyword=EP1168
Cost for the genuine HD ones is €130... And given that you can't get them, the Pedders parts are a solid ( no pun intended) option :y
Vega
  • The Netherlands
    • Omega Saloon 3.2
« Reply #2 on: 08 June 2018, 16:14:04 »
I tried PU, to much noise and vibration.
So no PU.
« Reply #3 on: 08 June 2018, 17:49:56 »
So no PU.
Pedders or unproven source from elsewhere?
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
« Last Edit: 08 June 2018, 20:43:55 by Chazza12 »
« Reply #5 on: 08 June 2018, 20:48:14 »
Not even close ;D
« Reply #7 on: 08 June 2018, 23:44:33 »
Again not even close...
Yes they look similar, but Op is after the factory heavy-duty ones as fitted to heases and ambulances... As per the part number.
Chazza12
  • south yorkshire
« Reply #8 on: 09 June 2018, 00:11:46 »
<a target="_blank" href="http://oemcats.com/checkout/379ca1e8442541ccf0bc2834331e8832.html">My GM parts list</a>
Vega
  • The Netherlands
    • Omega Saloon 3.2
« Reply #9 on: 09 June 2018, 11:41:30 »
oh so its rear ones.
Yes, like these but then solid and stiffer but flexible.
laney101
  • liverpool
    • omega elite v6
« Reply #10 on: 01 July 2018, 19:56:49 »
monaro and vxr8 use same rear doughnuts bushes im sure.. see if their part numbers any different as may be firmer
« Reply #11 on: 02 July 2018, 00:00:31 »
Half 'dangle berries'...
VXR8 has a completely different arrangement for the rear subframe... Similar to E39 5 series.
Monaro is identical part number to the Omega ;)
