Author Topic: satellite finder kit  (Read 2080 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 09 June 2018, 15:21:10 »
Anyone use the cheap (about £12) devices to help you adjust your satellite dish. Which one do you recommend ?
Ours has gone slightly out of alignment yet again and the only guy I know of that is prepared to travel to our remote area is booked up for weeks.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: satellite finder kit
« Reply #1 on: 09 June 2018, 16:36:51 »
I use a cheapo slx jobbie and a similar slx for ariels
they use a 9volt battery IIRC when ordering ,which may not be included  :y
https://www.screwfix.com/p/slx-satellite-finder-meter/27154
you can probably find cheaper  :y
I've also adjusted the dishes before using the built in lnb signal strength bars in the service menu (sky+hd boxes)
« Reply #2 on: 09 June 2018, 17:00:05 »
Any of them. They are pretty dumb devices that don't need anything clever.
Varche
    • Golf Estate
« Reply #3 on: 09 June 2018, 17:07:46 »
I changed the LNB as that was on the way out and got a picture using " How is that looking on strength?" to my assistant via a walkie talkie. The Sunbird GI mini boxes I use display the signal briefly when you change channel.
Wanted something a bit more scientific. I think the key thing will be to get something that includes the connecting lead. That would be a beggar to source here where the locals use tradespeople for everything still (except building where they all are experts - they think).  This CSL product looks to fit that bill.
https://www.amazon.co.uk/sat-finder-high-quality-positioning-sensitivity-instructions/dp/B00O0YA868/ref=sr_1_3?ie=UTF8&qid=1528553709&sr=8-3&keywords=satellite+finder
The Boy - spot on will get that one ordered :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #4 on: 09 June 2018, 17:17:06 »
Tape all connections with self amalgamating tape and any spare terminals on the lnb if quad or octo  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #5 on: 09 June 2018, 17:20:58 »
heres a Zirk tip that I use, once you got the LNB and Dish where it needs to be and a good Signal, tape a 2p piece over the center of the LNB then re adjust for best Signal or Picture, Lock up the Bolts, re confirm alignment and then remove the 2p, that way youve got the best possible signal and alignment ready for bad Weather etc.
« Last Edit: 09 June 2018, 17:23:26 by zirk »
zirk
  • Epping Forest
« Reply #6 on: 09 June 2018, 17:25:37 »
And dont forget the Skew adjustment on the LNB
Varche
    • Golf Estate
« Reply #7 on: 09 June 2018, 18:56:46 »
 :y thanks.
Varche
    • Golf Estate
« Reply #8 on: 16 June 2018, 14:03:10 »
Update.
Arrived. Worked a treat. Simple to use. :y
Page created in 0.038 seconds with 20 queries.
