Author Topic: X30 block with y26 head  (Read 7337 times)
olm
  • spain
    • 3.2 v6 sport estate
« on: 11 June 2018, 03:27:04 »
Hi, I have a Y26se engine and I wold like swap to x30xe, but, my engine has low milleage, and used x30 has high milleage, so I thought that use a x30 block, with new rings and bearings and use my heads with new gaskets, how would that be? Compression Ratio?
« Last Edit: 11 June 2018, 03:29:30 by olm »
Re: X30 block with y26 head
« Reply #1 on: 11 June 2018, 09:53:10 »
Waste of money, either fit the 3.0 with all the 2.6 electrical (sensors/coil packs/throttle) and call it done. Or if you are determined to spend money, by a crate 3.2 and fit that ;)
Bit of a moot point though, seeing as you're on internet rather than earth, so you won't be able to drive it ::)
« Reply #2 on: 11 June 2018, 10:13:11 »
If you put 2.6 heads on a 3.0, you'll end up with a dangerously high compression ratio, IMHO.
Fit the 3.0 as it is with the 2.6 ancillaries and loom. Mile4age doesn't really trouble these engines.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #3 on: 11 June 2018, 12:44:24 »
Daz did this to my cousins 2.6 when the bottom end went , 2.6 head on 3.0 block and it ran sweetly with no ill effects
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #4 on: 11 June 2018, 15:04:04 »
As Kev sugested above, Daz fitted the 2.6 plenum and other DBW bits to the 3ltr block and ported head from Obi  ;)
And yes, it did go very well  :D :y
olm
  • spain
« Reply #5 on: 11 June 2018, 17:54:35 »
Yeah. And it runs with the 2.6 ECU?
« Reply #6 on: 11 June 2018, 20:15:44 »
Pull the 2.6, remove the loom throttle body and sensors and fit them all to the 3.0. Fit the 3.0 and call it done.
That's the basics, obviously a cambelt kit would be a good idea. Also double check that the cylinder heads have the two bolt holes for the individual coil packs, post '98 3.0 have them :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #7 on: 11 June 2018, 21:29:19 »
That's the basics, obviously a cambelt kit would be a good idea. Also double check that the cylinder heads have the two bolt holes for the individual coil packs, post '98 3.0 should have them :y
Fixed,, some didn't, the early my2000,, 3.0L didn't.
Hoof'land storeman.
« Reply #8 on: 11 June 2018, 21:49:36 »
Fair point... It was done for the Catera going dbw, plus various gm products which had that lump :y
olm
  • spain
« Reply #9 on: 12 August 2018, 07:26:09 »
Well, finally I have a x30xe. Itīs from vauxhall  :) and itīs curious because is from a 98 omega prefacelift but has long intake manifold as my y26se. Any problem with the two holes for the coil packs?
« Reply #10 on: 12 August 2018, 11:15:48 »
The problem would be that they are missing...
Pull a coil pack from the 2.6 and you will be able to compare directly  :y
olm
  • spain
« Reply #11 on: 12 August 2018, 12:06:39 »
I will see it soon then i will start with the swap. I do not think it's hard to adapt, right?
« Reply #12 on: 12 August 2018, 13:25:19 »
You need to know before you start.
  • Auckland
    • Mazda MPV
« Reply #13 on: 12 August 2018, 17:47:45 »
Do the coil packs need the retaining bolts to give a good earth/0 volt path to the cylinder heads?
If not then the rubber boots will probably stop the coil packs from moving (much) :P
« Reply #14 on: 12 August 2018, 18:08:05 »
They don't... But I wouldn't chance it...
Page created in 0.026 seconds with 21 queries.
