Author Topic: Just back from Serek's Garage.  (Read 4591 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« on: 13 June 2018, 17:27:37 »
Top bloke :y
I like red cars
Re: Just back from Serek's Garage.
« Reply #1 on: 13 June 2018, 17:33:32 »
Yup  :y
What did you have done?
Think if I got an XF/XJ I'd seriously consider driving to his for servicing needs. (that's if he works on them)  ;D
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #2 on: 13 June 2018, 17:35:14 »
Yup  :y
ATF, fuel filter, rear diff oil change and brake fluid.
I like red cars
serek
  • huntingdon
    • 3.2 mv6
« Reply #3 on: 14 June 2018, 10:43:05 »
Was good To see you  :)
This Merc is nice spec and mint condition
Glad you had safe journey home
serek
  • huntingdon
    • 3.2 mv6
« Reply #4 on: 14 June 2018, 10:44:15 »
Yup  :y
Have x351 today for  rear arms as bushes gone
2x arm and some bolts just over £500  :o
« Reply #5 on: 14 June 2018, 14:11:40 »
Yup  :y
 :o
This puts me off the big Jags  :(
« Reply #6 on: 14 June 2018, 14:17:38 »
Because the small jag parts will be soo much cheaper ;D
A pair of Genuine Zafira wishbones fitted won't give you much change from £400 ;D
« Reply #7 on: 14 June 2018, 14:38:37 »
Yup  :y
 :o
A friend of mine just had to put his XF in for an "oil dilution service" - i.e. the regen cycles (and he does a commute similar to yours, daily) have watered the oil down with diesel... that puts me off! ;D
« Reply #8 on: 14 June 2018, 14:42:51 »
Powerflex rear bush kit - £70  :y
Meyle HD rear arms are about £120 each
« Reply #9 on: 15 June 2018, 11:18:36 »
When I got mine, the front arms were shot. TOPix says you can only change the bushes once/twice (would need to double check)  before you have to replace the arms. So Gixer and I poly'd them :y.  They were a basted to press in, mind ;D.  I think the polys for that were about £120, but I could be wrong - they were 3 part polys, a larger black part pressed into arm, and then the usual 2 purple bits pushed into that, with the metal tube.
Thats my plan as bushes fail, replace with poly.  Powerflex do nearly the entire set.
« Reply #10 on: 15 June 2018, 11:20:41 »
Yup  :y
Serek would have got the job to do my wheel bearing had I felt the bearing could have driven that far.  As I wasn't confident it would (massive play, scored the disc on the brake calliper mounting bracket, which itself was limiting the play on it) :y
