Pages: [1] 2 3  All   Go Down
Author Topic: Throttle position sensor  (Read 12408 times)
Migalot
  • London
    • Omega 2.6 2002
« on: 14 June 2018, 13:23:46 »
Can anyone tell me exactly where to find the TPS on a 2.6V6 2002?  ???
Thanks in advance.  :y
Re: Throttle position sensor
« Reply #1 on: 14 June 2018, 13:29:52 »
There are two... One on the throttle body and one on the pedal...
Code for it is usually due the the plug being slightly loose on the throttle body... Cable tying the plug together tightly usually resolves.
Can also be a sigh that the breathers and throttle body are gummed up...
Check both :y
Migalot
  • London
    • Omega 2.6 2002
« Reply #2 on: 14 June 2018, 14:54:11 »
Thanks, Doc, but why is there only this one type shown here? Does this one go on the throttle body?
Can't see one for the pedal listed.
http://www.vehiclepartsdatabase.com/vehicles/allprivateroadvehicles/opel/omegab/26v6/y26se/18241/throttlepositionsensors
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 14 June 2018, 15:04:25 »
As said, check the Plugs and wiring first, then do Ing. restart before seeking for Parts, they very rarely fail.
« Reply #4 on: 14 June 2018, 15:10:25 »
;D
 Sorry to piss on the parade, but that IS the pedal sensor ;)
As Zirk confirmed, see my last. It will be a combination of gummed up throttle body and a loose plug on the throttle body...
Migalot
  • London
    • Omega 2.6 2002
« Reply #5 on: 14 June 2018, 15:36:24 »
Appreciate your input, guys, but you're barking up the wrong tree!
Essentially, I have a new throttle position sensor (as per link), which I bought a long time ago and just wanted to fit it. I don't have a specific TPS problem, but I do have a gearbox issue which Stephens Engineering (autobox specialists) reckon may well be an electrical issue. I am therefore trying to go through the less-expensive sensors, etc. before looking into the box itself.
After having a new crank sensor fitted, the autobox issue disappeared ENTIRELY for three months. It then started to come back (I seem to remember it started to feel a bit odd again after having a jolt in the car from a pothole, but I may be wrong). Essentially, the box works fine on straight acceleration and changes perfectly, but if driving sedately at 30mph, the revs can suddenly rise by 1,000rpm and then it will go into 3rd with a jolt, causing limp home mode and management light on. It always resets after a restart. I've had the codes read and they are
P0730 Incorrect Gear Ratio
P1625-002 Controller voltage switch signal too low
It is NOT an ATF level issue (already checked). The issue first arose about 4 years ago as an irritating, but infrequent problem but it seems to be occurring more frequently now. As I said, Stephens reckon I need an autoelectrician to check it over. Problem is autoelectricians are as rare as hen's teeth round here.
Back to the TPS: Is it straightforward to fit my new one to the throttle? I may as well as there's no cost involved.
« Reply #6 on: 14 June 2018, 15:46:50 »
Was the crank sensor a genuine GM one purchased from a genuine VX dealer that you genuinely had to walk in to?
If not, try again :y
Equally, if that isn't a genuine tps sensor (as above) you are wasting your time fitting it as a) it isn't the problem, and b) won't solve anything (might actually make it worse).
And, again, check the throttle body items.
« Last Edit: 14 June 2018, 15:51:49 by Doctor Gollum »
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #7 on: 14 June 2018, 15:50:52 »
You have two fault codes that relate to gearbox electrical problems, yet you blame a part that isn't anything to do with either of them. That's not likely to fix the fault.
Migalot
  • London
    • Omega 2.6 2002
« Reply #8 on: 14 June 2018, 18:54:05 »
I'm not blaming anything specifically. Even Stephens Engineering thought it could be the ECU (it's not, as I have swapped it and checked) or a sensor fault.
Migalot
  • London
    • Omega 2.6 2002
« Reply #9 on: 14 June 2018, 19:10:03 »
Just looking around the web and found an Opel site that says error code P1625 is a relay power supply fault.
Could I have a faulty autobox relay?  ???
May take a look tomorrow.
« Reply #10 on: 14 June 2018, 19:13:04 »
Which ecu  ::)
And at risk of repeating myself, where did you buy the crank sensor from? The fact that this cured the issue, and then only for three months tells me two things... 1. It's the problem and 2. That it wasn't a genuine sensor.
The throttle body plug is a recurring weak point and unless the breathers are spotless, the throttle body is probably the colour of molasses inside.
Individually people here, myself included have hundreds of thousands of miles experience of these, collectively there's millions of miles experience.
It's your car, so ultimately you will do whatever you want to do, be try to be mindful of a few things... Advice will be given freely based on the information provided. If you seek advice, ensure that you provide accurate information and also that upon following said advice, you report back with some sort of update. ;)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #11 on: 14 June 2018, 19:22:29 »
In the end you will end up swapping that box....this faults been on here loads of times...it always ended with a solenoid valve in the box getting the blame....ive had it Amba had it and a few more.and the cheap simple cure was a AR35.
Migalot
  • London
    • Omega 2.6 2002
« Reply #12 on: 14 June 2018, 21:32:39 »
Which ecu  ::)
Transmission ECU. :y
As far as the crank sensor is concerned, I simply can't remember its provenance as I bought it when I originally got the car and kept it in the storage compartment in the boot.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #13 on: 14 June 2018, 22:04:09 »
Getting back to the original point. Out of curiosity I have been out and had a look for the TPS on mine (assuming in the region of front of plenum) but cant find it !  ??? :-[
Migalot
  • London
    • Omega 2.6 2002
« Reply #14 on: 14 June 2018, 22:10:47 »
Have you a GM part number for the crank sensor, Doc? This site has genuine Siemens sensors, but there are apparently three alternatives:
http://www.lmfvauxhall.co.uk/Crankshaft-Sensor-Omega-V6.html
Cheers.
Pages: [1] 2 3  All   Go Up
Page created in 0.111 seconds with 20 queries.
