Pages: 1 [2] 3  All   Go Down
Author Topic: Throttle position sensor  (Read 12277 times)
Re: Throttle position sensor
« Reply #15 on: 14 June 2018, 23:09:17 »
'Bosch' 90540743, which is also applicable to the Y26SE, X30XE and Y32SE engine variants.
There do :y
« Last Edit: 14 June 2018, 23:13:31 by Doctor Gollum »
« Reply #16 on: 14 June 2018, 23:12:46 »
Getting back to the original point. Out of curiosity I have been out and had a look for the TPS on mine (assuming in the region of front of plenum) but cant find it !  ??? :-[
Throttle body tps is built into the actuator motor/throttle body assembly  :y essentially it's an extra resistance circuit on the potentiometer... *
Pedal one is as alluded earlier in the thread, but both register in the engine ecu :y
*I stand graciously to be corrected on this specific detail  ;)
« Last Edit: 14 June 2018, 23:14:45 by Doctor Gollum »
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #17 on: 14 June 2018, 23:24:35 »
So, the tps unit which is located with two screws, which Im thinking of, is from the 2.5 / 3.0 only  ?  :-\
Like this.
https://www.ebay.co.uk/itm/Vauxhall-Omega-MK2-B-3-0-V6-Variant2-Intermotor-Throttle-Position-Sensor-TPS/291703199090?hash=item43eadd9572:g:q3IAAOSwgZ1Xq7QP
Migalot
  • London
    • Omega 2.6 2002
« Reply #18 on: 14 June 2018, 23:29:44 »
There do :y
Ta muchly! :y
« Reply #19 on: 15 June 2018, 00:11:22 »
Like this.
If it's in the engine bay, then yes... Pedal one similar if not the same ;)
grifter
  • Paisley, Scotland
    • Omega 2.6 CD / Elite 3.2
« Reply #20 on: 15 June 2018, 10:54:29 »
There is a plug on left side just under and to the left of bellows air intake bit, i think that's where it resides. My plug securing clip was broke off when i done TB so had to secure plug with tie wrap as it was actually causing running problems and codes
« Reply #21 on: 15 June 2018, 12:05:18 »
I would buy the crank sensor from your real, local dealer, rather than grey stock from elsewhere.
You may get away with it, but a large number of people here haven't
« Reply #22 on: 15 June 2018, 12:06:53 »
I doubt either the APS or TPS are the issue here, as they both have dual feedback circuits in,  and will raise a code if they don't match.
Migalot
  • London
    • Omega 2.6 2002
« Reply #23 on: 15 June 2018, 12:09:37 »
The local dealer didn't have one (even in their whole group), but I ordered this:
https://www.vauxhall-car-parts.co.uk/acatalog/VAUXHALL_OMEGA_CRANK_SENSOR_-_90540743N.html
Should be OK!  :y
« Reply #24 on: 15 June 2018, 12:12:06 »
Cancel, and ask dealer to order one. Will be there by prob Monday if you order right now
« Reply #25 on: 15 June 2018, 12:14:10 »
Should be OK!  :y
Pretty certain with that site, the N means a non genuine part
« Reply #26 on: 15 June 2018, 12:47:32 »
You reckon ::)
The sub £16 price tag is a clue... :D
Get a refund and spend the money doing what you were told to do.
Migalot
  • London
    • Omega 2.6 2002
« Reply #27 on: 15 June 2018, 12:57:10 »
Should be OK!  :y
Oh. OK.  :o
Fair do's, but the Vx group didn't have one, so you pays your money, and you takes your choice.
At under £20, I can live with it if it doesn't last as long as an OEM.
« Reply #28 on: 15 June 2018, 14:00:12 »
That I find next to impossible to believe. Granted, some/lots of Omega parts now have to come from Germany, which adds a day, but as its used on newer cars, I would be surprised if GM had none in the UK.
« Reply #29 on: 15 June 2018, 14:10:38 »
Right, enough of this bullshit...
Genuine GM V6 DBW crank sensor is as follows...
£85.20 INCLUDING VAT, NO DISCOUNT ie this is the maximum price. Feel free to haggle better.
Available within two days from Central Stores in Germany.
Now quit making excuses and get done.
« Last Edit: 15 June 2018, 14:12:22 by Doctor Gollum »
Pages: 1 [2] 3  All   Go Up
