The agony of toothache.
Started by Field Marshal Dr. Opti, 27 June 2018, 16:30:37
Quote from: dave the builder on 27 June 2018, 19:08:53
Quote from: TheBoy on 27 June 2018, 18:59:10
Quote from: dave the builder on 27 June 2018, 18:23:05
so you pay a monthly fee then
Nope.
yearly ?
or have some other private health insurance ?
or it was 20 years ago  :D ;D
Probably covered by his employer.......spoilt bastard.  ;D
Nope.
yearly ?
Nope, no subscription or other insurance.  I didn't think the charges were unreasonable, and when I found, following the last 2 checkups, that I had checkup credits due to the work, I thought it was excellent value.
dave the builder
Quote from: TheBoy on 28 June 2018, 20:39:58
Nope.
yearly ?
WOW
sounds too good to be true
sounds too cheap even if you did have a dental plan subscription
though , long nose pliers are an even cheaper option  :D ;D
Quote from: Sir Tigger QC on 27 June 2018, 19:12:57
I had to have a wisdom tooth out in Bucharest a few years ago when I was working there.  ::)
It was an interesting experience, they made me wear a lead chain mail poncho thing when they X-rayed me!  :o
It was only twenty quid, though and like Lord Opti I was desperate to be out of pain!  :(
Was the dentist situated in a BDSM club, Sir Tig?
Were you allowed to keep your trousers on while they performed the extraction? ::) ::) ::)
Quote from: Field Marshal Dr. Opti on 29 June 2018, 13:56:15
The dentist was a youngish Romanian girlie!  :)
She was only a wee little thing and struggled to pull the tooth out.  :-\  At one point in the proceedings she climbed up on the chair and straddled me to get a better grip on things.   :y. I kid you not!  ;D
I'm sorry to say that I let the side down and didn't score for England that evening, as the pain kinda distracted me....  :(
Migv6 le Frog Fan
I had a similar experience about 15 years ago. Young, slightly built female dentist was extracting a back tooth and got it half way out but didn't have the strength to pull it the ret of the way.
In the end her and her assistant were pulling and yanking at it together until it eventually came out. then had to have the hole in the gum stitched up to round off a pleasant day::)
My worst experience was about 10 years ago when I went to have another troublesome back tooth extracted. It came out in parts, one root at a time and the dentist showed me that each root had a sack of puss attached to the end of it.
He then explained that these had been growing through the wall of my sinus, so that now had a big hole in it, and this was potentially a serious problem. So he then had to slice my gum into strips and then sew the strips over the hole.
He told me not to sneeze for 3 months, at which time I told him that it was spring time and I suffer from hayfever, so that was unlikely to happen.
He mentioned that I was lucky he was a qualified dental surgeon rather than just a common or garden dentist. I didn't feel very lucky.  ;D
He then prescribed me very strong painkillers as I would definitely need them once the numbing stuff had worn off.
I didn't make it to the chemist before that happened. I was driving along the road screaming to my self in agony. ;D
When I got to the chemist, they told me they couldn't give me the painkillers as the dentist had no legal right to prescribe tablets that strong, so I had to settle for less pokey ones. ::)
I avoided  dentists for a while after that. Don't have that many teeth left now, so the worst of it must be behind me.  :D
Rods2
Got an abcess under a bottom front tooth over 30 years ago. Where the swelling made the tooth hit my top teeth, I made the bad move of pushing down on the tooth and bursting the abcess and went into toxic shock. A few hours of sweating like being in a sauna while shivering like an Eskimo where looking back I think I had Sepsis. After this the tooth was always slight loose and has got looser and looser and I easily pulled it out with my finger a couple of weeks ago and you can see how badly the root part of the tooth is damaged. :o :o :o
For any slight pains these days where I have poor gums I've recently bought a set of detal tools and use those to clear around the painful part and it is normally much better or perfectly fine the next day. :y
dave the builder
Quote from: Rods2 on 30 June 2018, 11:25:46
For any slight pains these days where I have poor gums I've recently bought a set of dental tools and use those to clear around the painful part and it is normally much better or perfectly fine the next day. :y
I swear by knipex stuff, not cheap , but some jobs require the right tools  :y
dental tool kit clicky
Quote from: dave the builder on 30 June 2018, 12:33:58
;D ;D ;D
Bottom right - universal extraction tool..
Quote from: aaronjb on 30 June 2018, 22:26:54
;D ;D ;D
I think it was something like that, that the Romanian girlie dentist used on me.  :-\
Although when she straddled me, it looked more like a large set of bolt croppers that she was wielding!  :o  Maybe the opiates that she administered before hand altered my perspective a little?  :-\  ::)  ;D
