Author Topic: Five down, two to go  (Read 2731 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 28 June 2018, 17:23:04 »
I used to take a pride in running seven cars for my family, now the cars are getting old, so am I, and I find it hard work. Next car, MOT expires 7th July, is Ben's 1999 2.2, the one I was dreading. After emptying it of 2 bags of rubbish last night, I gave it a preliminary inspection.
Diagnostic live data was encouraging; O2 loop soon closed, and mixture lambdas 1 & 2 switched lean-rich-lean-rich commendably. Removed cill covers and found a little rust at the back both sides, but I've seen worse. Nasty external hole in front base of n/s rear wheel arch worried me most.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Five down, two to go
« Reply #1 on: 28 June 2018, 20:22:27 »
easy enough to sort a problem if you know what the problem is
stick a metal plaster on it with a sparky gun  ;D
hope you don't find anything else and you have an easy time of it this MOT  :y
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 30 June 2018, 11:28:01 »
It will need quite a big plaster.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #3 on: 30 June 2018, 12:20:51 »
it is but a flesh wound  ;D
 metal plasters plural then  :y
I've seen other vauxhalls with rust there  ;D
