Had a call from EDF yesterday
Started by STEMO, 12 July 2018, 11:41:41
Alnico Blue
#60
Quote from: STEMO on 21 July 2018, 10:48:08
I was paying £60 a month for my water when it was metered in my last house, 3 beds, 1 bathroom. This house, 4 beds, 2 bathrooms has no meter, £36 a month.
I'm going to resist as long as I can.
Me to Stemo  . . . but if & when it eventually comes , I will be able to check for any leakage etc. as  I work in the water industry & know what to look for ::) ::)
I can foresee some large bills arriving for metered  families with their teenage kids who spend best part of an hour in the shower  :o :o :o   or the old lady who waters her lawn & flowerbeds every day. I won't even go down the swimming pool road  ::) ::) ::)
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
dave the builder
I Repaired a water leak for a pensioner last year (lead supply pipe under a kitchen extension).
calculated (flow rate after - flow rate before repair x time )
5 Olympic swimming pools worth of water at least (over 4 years at least)  :o
monitoring for ground movement now  ::)
to be fair, it was a 130 year old common supply pipe, serving 20 houses ,
local supply company had been told about lack of pressure over many years ,sent out workmen ,who failed to find the leak, over many years,
still a common lead supply pipe serving 20 houses because the authority won't replace under lead replacement scheme  >:( and getting 20 home owners to pay is untenable .
Quote from: dave the builder on 21 July 2018, 11:51:27
Try finding a plumber who can sweat a joint nowadays.
dave the builder
Quote from: STEMO on 21 July 2018, 12:00:15
I have done it in the past , just drill out the lead bore ,slightly oversize , flux, map gas , jobs a goodun . ;D
can't do it live though ,
and turning water off to 20 houses would upset the locals  ;D
so I opted for a lead loc to mdpe fitting , with strain relief clamp
(because the supply pipe is 28 + L/min at the only stop cock to 20 houses ,the leak being the very last property in the run  ::) )
Alnico Blue
Common supplies are a total pain for my department  . . . .along with the  present day totally inexperienced read it in a book & got a degree, type management . . .who would not know the difference between a water supply pipe & a pipe that you stuff with ready rubbed & light with a match   >:( >:( >:(
dave the builder
Quote from: Alnico Blue on 21 July 2018, 12:40:34
the supply company have share holders to answer to ,need to save money  :P
I did offer a solution of providing them 3 individual supply pipes to the boundary (within 4 meters of a 4" malleable iron main ,shown on their GIM geographical infrastructure map) that would comply with the requirements for the lead replacement scheme , (the property with the leak at the time was an 80 year old pensioner ) they said the GIM was wrong , would need to send a team to dig it (which they have not  ::)) and other excuses
Then there is the issue of creating a "dead leg" when disconnecting from the common supply pipe ,which I proposed the fitting of an outside tap at the end of the common supply ,thus leaving no dead leg , the supply company said that was unacceptable. yet at the end of the street ,is a 4" fire hydrant dead leg ,some 20 feet plus long .(shown on GIM and is there for sure )
i'm not impressed  :(
redelitev6
Try finding a plumber who can smoke  a joint nowadays. :y
dave the builder
Quote from: redelitev6 on 21 July 2018, 13:07:21
I think there are quite a few about still ,from some of the plumbing I have seen  :y
they just don't advertise as "pot smoking cowboys" who clearly  don't understand good plumbing or just don't care , only there for the tea n biscuits  ;D
Shackeng
Sounds excessive, did you have a leak?  :o :o :o In our 5 bed detached with only two of us, with 2 bathrooms + 1 en-suite, kitchen, utility with washing machine (used daily it seems) and dishwasher, cloakroom, fish pond that requires frequent top-ups in this weather. We do only shower daily, rather than baths.
Metered water is £20 per month.
I was lucky enough to have my meter fitted internally immediately after the rising main. ::)
Quote from: Shackeng on 21 July 2018, 15:04:51
Wifey fills the bath every day  ::)
Shackeng
Quote from: STEMO on 21 July 2018, 16:04:25
'Nuff said. :-X
If you tell her its costing £X per month perhaps she will reconsider. ???
Quote from: Shackeng on 21 July 2018, 18:09:25
'Nuff said. :-X
I tried, Chris. But I got short shrift and I'm getting to the age where I want/need a quiet life.  :)
Shackeng
Quote from: STEMO on 21 July 2018, 19:00:57
'Nuff said. :-X
Understood. :y
Rods2
Lovely, white water in a morning with all those lovely brain numbing lead minerals in it, t'tough up north, did I tell you it's t'tough up north, what, what, what was I saying, about Wombles. ::)
dave the builder
Quote from: Rods2 on 24 July 2018, 00:15:04
Hence, all water that I drink at home passes multi-stage filtration, I'm well aware of the p155 poor,  antiquated, water supply infrastructure we pay so much for to use  :-X lead is just one of many contaminants  :y
