Author Topic: Facelift Estate tailgate loom plug question  (Read 3601 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 15 July 2018, 09:58:19 »
This is the tailgate loom plug (car side)
As you can see, it has a single brown wire / yellow trace with a small plug on it.
Were the hell does this plug into ??
The main plug was disconected but this one was not seen and pulled away when the loom was pulled out  :(
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Facelift Estate tailgate loom plug question
« Reply #1 on: 15 July 2018, 19:44:30 »
Guessing at hrw.
Hoof'land storeman.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #2 on: 15 July 2018, 21:13:55 »
Guessing at hrw.
Nope
That one definetly goes through the plug  :y
The door pin switch has 2 cables on were as the old prf one only had one  :-\
Pretty sure it is one of those  :-\
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #3 on: 15 July 2018, 21:22:17 »
My Haynes manual is down at the garage so can't check wiring diagrams for you,have you checked for any power to it when things are turned on or is it permanently live?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 15 July 2018, 21:29:35 »
Tbh, had such a shit day i've left it and if something doesn't work tomorrow, i'll have a dig around for the other end when i've got the caravan on site and sorted  :y
Definitely in holiday / cant be arse mode now  ::)
I'll stick something on here if it causes problems  :y
Thanks anyway  :)
« Reply #5 on: 15 July 2018, 22:18:10 »
I have the tailgate loom in the garage, I shall peruse it tomorrow. Currently working ::)
« Reply #6 on: 16 July 2018, 09:53:28 »
Just remembered :-[
Back in a sec...
« Reply #7 on: 16 July 2018, 10:01:25 »
Just remembered :-[
Back in a sec...
OK, facelift tailgate loom is in two pieces, second plug lives in main body of tailgate... other end of your mystery plug is, indeed, the tailgate contact switch :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #8 on: 17 July 2018, 12:46:35 »
Found the other end last night Al
All working so I’ll start building up the wax and get the trim bits on today  :)
Cheers  :y
