Author Topic: A spot of maintenance part 2  (Read 1949 times)
Markjay
  • London
« on: 04 December 2006, 11:34:55 »
For those of you who actually recall my previous post....
The sunroof was making and odd noise for some time now, in fact for the past two years. When opened, about 2/3 of the way through it would make a loud thud but open normally otherwise. I actually asked Vx to check this when the car was booked-in for service, their technicians 'could not fault it Sir, but we have lubricated it for you'. So I lived with it.
A couple of months ago, the roof wouldn't close. It went forward through 2/3 of the way, but then it stopped and opened again. On closer examination, the wind deflector flap at the front was not folding down, and the mechanism that is supposed to prevent accidental amputations by backing-up when sensing resistance was opening the roof again.
This seems to be a deterioration of the previous condition, i.e. the flap wasn't moving freely and the thud noise was the result of the flap popping-up at once instead of gradually lifting, and eventually is partially seized - it worked if you pushed down the flap by hand, but not when the roof was closing.
Looking at the rails, it seems that Vx applied a generous amount of grease to the actual tracks on both sides of the roof but not to the flap pivoting points at the front which were dry. Applying a spot of my ole' faithful multi-purpose grease directly on the flaps pivots solved the problem - the roof now closes first time, and opens quietly and without the thud!
Alas, no more Omegas....
Gwilym
  • Bridgwater, Somerset, UK
Re: A spot of maintenance part 2
« Reply #1 on: 04 December 2006, 12:14:23 »
Excellent news. See, you don't need a Vx Mechanic to sort it
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
nixoro
  • Hitchin, Herts
« Reply #2 on: 04 December 2006, 12:19:24 »
Well done on the cheap fix, it just goes to show you dont need Vx to get a job done. :y
hotel21
  • The Kingdom of Fife
« Reply #3 on: 04 December 2006, 12:24:50 »
Well done!  How long did it take you?
Guess minimum of 30 mins (or less) at a nominal VX rate of £50 per hour plus a can of spray grease (at full retail) of £4.99.
You just earned minimum £30 quid (if they charge a half hour min rate) or so to spend on yourself at Christmas!   [smiley=tekst-toppie.gif]
Markjay
  • London
« Reply #4 on: 04 December 2006, 12:50:06 »
I followed the advice provided elsewhere on this forum and changed the plastic washers on both front doors, crack-of-doom noise gone, the cost was next to nothing and it took 5 minutes.
I then used a touch of grease to lubricate the lower end of the auto gear selector, one clonking noise gone...
Now I sorted-out the thud from the sunroof.
The point is that a little bit of TLC you can transform your car from a rattling old banger to a quiet luxury saloon!   :)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #5 on: 04 December 2006, 17:38:27 »
Well done MJ :y
I like red cars
