What is a HOLOX?
Started by Bigron, 22 July 2018, 17:25:02
Well, for a start, your computer hasn't even noticed it...
Quote from: STEMO on 22 July 2018, 18:08:48
Are you guys thick, or what? The Holox BT541 uses the Skytraq Venus 521 chipset which supports AGPS. Skytraq provide a free AGPS download application for Symbian and Windows. Time to lock, and typical accuracy are very good when AGPS is used (can be a bit tempramental without it). Early firmware versions had problems with track drift (firmware is upgradeable, but difficult to find the latest version). The BT541 has a motion detector (sounds like a ball bearing in a box) that allows the device to go into a low power mode when not moving. This can give a battery life of many days depending on usage.
;D ;D ;D
Quote from: Bigron on 22 July 2018, 18:13:33
But what can I use it for - apart fom the said suppository?!
Ron.
Ermmmmm.......nowt. You can watch the three lights. If you get all three, you win a coconut.  ;D
dave the builder
[/quote]
Ron.
Quote from: dave the builder on 22 July 2018, 17:45:38
paperweight
door stop
Bigron
I think I know its function - it has enabled you all to take the Michael Bliss out of me!  :-[ :-[ :-[
Ron.
dave the builder
Quote from: Bigron on 22 July 2018, 18:22:37
Ron.
It clearly states that internet forum members will "extract the urine" in the manual , which you clearly haven't read . ::)
fortunately,  the only computer equipment old enough to hack or communicate with your pc is safely under lock and key at the British Museum,  so don't panic  :y
ronnyd
I,ve got an old road atlas you can borrow Ron lad. ;)
Rods2
If you paid more than 50p you were robbed. :o
But here are three indispensable, I can't manage without it, uses:
1. Of all the suggestions I've seen so far on here, this is the best one. With your house windows open in the hot weather, use it as a door stop to stop any cooling breeze from slamming a door shut. :y
2. During the winter plug it into your laptop and the 0.1W of mighty heat will help keep your house as warm as toast. ;D
3. Finally, when you go on long bike ride and get lost in the middle of nowhere, plug it into your laptop, the GPS will show you where you are so you are no longer lost won't work and you will still be lost, but if you keep cycling for long enough, you will eventually reach the sea somewhere as we are an island. ;D
Bigron
Quote from: dave the builder on 22 July 2018, 18:39:56
Ron.
I HAVE read it, thoroughly, and inwardly digested it: I have been fully compliant with the strictures of that Space Corps Directive since I jouns the Forum, so I do know exactly what to expect.....and you didn't disappoint!  :y 8) :P
Ron.
dave the builder
The HOLOX manual Ron
you have NOT read the HOROX manual  ;D
Quote from: dave the builder on 22 July 2018, 21:47:44
In the interests of things on the internet having to be accurate, do you mean HOLOX or HOROX?
dave the builder
Quote from: STEMO on 22 July 2018, 21:49:25
touche  :y
obviously, Ron knows how to make Horlicks
it's written on the back of the jar  ;)
redelitev6
I was just going to say that  :y
Is it a HOLOX 321 or HOLOX 541 Ron?  ???
Bigron
It doesn't say - no markings except for the name.
Ron.
