Sensors
Started by STEMO, 22 July 2018, 18:31:56
dave the builder
Quote from: aaronjb on 23 July 2018, 10:25:22
Man alive, that all sounds complicated and expensive.. and L already wants to get rid of them to replace it with a hot tub, if I have to spend any more money on it she'll probably just let the cats eat the fish ;D
We already have a big filter with a UV lamp in it, but that seems to do the square root of sod all.. we can try feeding them less - no idea how much of the pellet crap they're actually meant to eat, mind ;D
just put in what they will eat straight away within 5  minutes  :y
the UVc lamp (bulb) requires replacement once a year and cleaning on a regular basis to work
that's if it is big enough to cope with the size of pond
be warned, hot tubs require constant monitoring of ph, chlorine, alkalinity, TDS levels etc etc  ;D
what about astro turf ?
or a nice slabbed patio  :y
Not sure I'd want to be in a hot tub in which someone has "dissolved solids". :-\
dave the builder
Quote from: Kevin Wood on 23 July 2018, 10:53:00
Think bath water,  skin, hair, cheese etc  ;D
plus hot tubs require heating and pumped water ,new filter cartridges etc
expensive unless used all the time
cheaper to have a dunk in the village pond  :y
Quote from: dave the builder on 23 July 2018, 10:58:51
Problem is, the "dissolved solids" in our village pond are now extra concentrated due to evaporation. :-\
dave the builder
Quote from: Kevin Wood on 23 July 2018, 13:55:59
Well, as DG would say "top up and report back "  :y
Actually I was going to run with eat the carp and fill the pond...  :D
dave the builder
Quote from: Doctor Gollum on 24 July 2018, 04:10:16
Sorry Doc  :-[
I see now,"top up and report back" would be  sticking a plaster on, rather than solving the problem once and for all
clearly, I should have looked at the bigger picture  :-[
