Author Topic: Rear disc replacement  (Read 22162 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Rear disc replacement
« Reply #30 on: 27 July 2018, 16:18:10 »
In over 20 years, I never ever saw the hand brake shoes on any of my Senators or Omega  ::)
I put it down to infrequent use  ::) ;)
You would see them when you change your rear discs.
They only do any serious retardation during MOT tests or in an emergency. The reason we strip them down is the actuator, depicted above, rusts and seizes up, destroying the 4:1 mechanical advantage.
The forum guide recommends stripping the handbrake down every 2 years; I doubt many members do that.  Haynes says you need to remove the hub and bearing to replace the brake shoes; forum members don't do that either.
I do it when the handbrake needs a mighty heave to hold the car on a hill; that's a sure sign the actuator has seized. It's not a trivial job, but one I find most satisfying.
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #31 on: 27 July 2018, 16:47:53 »
That's exactly what mine has been doing and getting worse over time.
Thanks for the info Terry  :y
« Last Edit: 27 July 2018, 16:56:42 by Andy A »
« Reply #32 on: 27 July 2018, 16:55:27 »
I never had need to change rear discs  ;) ;)
« Reply #33 on: 27 July 2018, 17:21:03 »
Clearly never had a later V6 then...  ::)
« Reply #34 on: 27 July 2018, 20:36:18 »
Am I correct that the pin should be solidly/permanently fixed to the swan part?
Both of mine have an oval hole where the pins go and the pins are very lose and won't stay in at all.
As has been mentioned, the pin is a separate part, and not a particularly tight fit.
« Reply #35 on: 27 July 2018, 20:37:51 »
Of all the Omegas I've had, I've one ever changed rear discs once, and that was due to a handbrake issue rather than a wear issue.
Although all but TBE have been non vented.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #36 on: 27 July 2018, 21:34:36 »
Out of the 3 Senator As 2 Senator Bs 1 Monza a PFL Omega and the present Fl Omega the only handbrake problem I've had was with the PFL Omega which I took a rear disc off[I was selling it to someone who wanted the interior for his Astra project] and found the backplate had rotted where the hold down pins were held.I believe MFL/FL went to the pins going through the back plate from the inboard side and held the shoes by spring/washer as most cars I've owned did,where the PFL cars the pins went through the shoes and were held by a shaped hole in the backplate like the Senator/Monzas did.
« Reply #37 on: 27 July 2018, 21:40:09 »
Which is why I ended up chasing one around the garage floor.. gave up looking for it, used one of my spares (I've got 2 or 3 full brake sets for the Jag - calipers, discs etc ;D XJ40, XJ40-V12 and X305!), then promptly found the original. The original is still stuck to the magnetic tool rail so I can't lose it again ;D
« Reply #38 on: 27 July 2018, 21:55:12 »
Correct. I wanted my Omega to look like an Omega ..... not an Astra G  ::) ::)
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #39 on: 27 July 2018, 22:07:46 »
Have changed lots of omega handbrakes. Basically every 2 years which is the control period in norway. Salt on the roads dont help. But both my omegas are 94-95 models. The new one is 97. And i see that the 97 has the brakeshoe pins the other way. With a small disc on the outside. The 94-95 omegas had the pins with the «tip» locked in the brakeshield with a 90 degree turn of the pin. Only a tiny amount of rust in the brakeshield and the pins let go and everything comes loose:p dont know how the 97 pins sat in the shield since when i changed Brakes on that handbrake seemed ok and i didnt want to mess with it. But obviously the arrangement was changed in 96-97 sometimes and the newer pins seem better.
Andy A
  • Bristol UK
« Reply #40 on: 29 July 2018, 10:08:08 »
Got a Saab 900 Shackle Kit ordered. Couldn't find a VX set.
« Reply #41 on: 29 July 2018, 18:28:12 »
 :-X
just looked up a full Brembo set of Discs pads and shoes with that discount code.  £157.03, must admit am tempted.
It will be the shit Brembo stuff. Not the decent stuff. Its just a cheap, nasty, aftermarket replacement/
Not recommended then . . . . .
Andy A
  • Bristol UK
« Reply #42 on: 02 August 2018, 13:41:18 »
Is there a tool for getting the spring and cap back onto the pins?
Tried the method with ring spanner in the tut but they will not go back onto the pins and lock onto the collar.
This thing is driving me nuts.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #43 on: 02 August 2018, 13:49:02 »
There is. But the problem will still be that the pin moves away from the cap and you can't put your finger on the back of it like normal. So whatever method you use to hold the collar you have to push on it and twist at the same time.
« Reply #44 on: 02 August 2018, 15:02:14 »
Long nosed pliers or a 10mm ring spanner.
Which is a choice of dexterity  ;)
Best have the swear jar ready :-X
