Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: Rear disc replacement  (Read 22152 times)
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: Rear disc replacement
« Reply #60 on: 04 August 2018, 18:36:34 »
Yes it sounds like the cable but
Re the adjustment
Make sure the handbrake mechanism lever is fully retracted (ie /hence slack cable)when adjusting the star wheel.and also ensure they both have a pull back spring on them or they will never run free properly.
In a perfect world you would slacken cable off,adjust each wheel then re adjust cable..
Pretty much the same as adjusting any if not all handbrakes.make sure all adjustments are done to mechanism first then take up cable
« Reply #61 on: 04 August 2018, 19:03:07 »
Unfold the bracket and refold around the new cable supports ;)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #62 on: 05 August 2018, 08:39:01 »
Started to get everything ready for the cable change today. I found a guide in the maintenance section.
I got sent a Pagid (84167) cable from ECP (108720198).
I read in the guide that the cables on both sides are slightly different in length. How different is the length suppose to be?
Just laid the new cable out on the floor to mark the longest side but I found both sides of the new cable to be exactly the same length.
« Reply #63 on: 05 August 2018, 08:52:28 »
Fit it, adjust and call it done ;)
Andy A
  • Bristol UK
« Reply #64 on: 05 August 2018, 10:02:23 »
Just for future reference Al. Are the the original VX cables different lengths or the same lengths for both sides from new?
« Reply #65 on: 05 August 2018, 10:45:00 »
Only ever fitted pattern so couldn't say :y
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #66 on: 05 August 2018, 13:07:08 »
Pattern parts :o :o Are you allowed to say that on here? ::) ;D ;D ;D ;D
« Reply #67 on: 05 August 2018, 13:28:04 »
I will burn in hell for less ;D
Pages: 1 2 3 4 [5]  All   Go Up
