Author Topic: What they called..  (Read 7390 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
What they called..
« on: 26 July 2018, 21:46:57 »
Anyone got any idea where i can get these from...They are the healights on front of a bait boat for carp fishing...it did have 2 wires attached.
I put a meter across them and got 6v so i know it gets a 6v feed..They are also very bright....That nut is 10mm..so you get the idea of the size...
« Last Edit: 26 July 2018, 21:52:05 by Steve B »
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: What they called..
« Reply #1 on: 26 July 2018, 22:23:04 »
I'd personally drill them out and silicone fix some new 6v LED's in place.  Classic cars, motorbikes etc use 6v, so plenty on the market.
EDIT:  Is that nut 10mm, or is it a M10 nut?
Steve B
  • Leicestershire
« Reply #2 on: 26 July 2018, 23:43:14 »
i used a10mm spanner to take it off
« Reply #3 on: 27 July 2018, 08:36:02 »
They look like standard panel mount LEDs to me - google "panel mount LED 6v" and you'll find lots, some that look darned near identical..
Or have a look through here - https://www.mouser.co.uk/Optoelectronics/LED-Indication/LED-Panel-Mount-Indicators/_/N-b1d1p?P=1z0yqrwZ1yox8bj (panel mount, forward voltage of 6V, in case my search parameters don't get stored in the URL)
« Reply #4 on: 27 July 2018, 09:58:04 »
Yep, me too.
Bear in mind with LEDs, though, that it's the forward current that's important. Unless they have an internal circuit to control the forward current (some do), they aren't safe to simply connect across a supply of a given voltage as you would a bulb.
Where a forward voltage is specified, this is usually a nominal value at a given current but will vary with temperature and between samples of identical LEDs so it's not a supply voltage spec. Normally, they'd be driven with a series resistor to limit the current, sometimes with a more elaborate circuit. It would be wise to check to see if they are being fed through a series resistor in this application as this determines what type of LED would be best as a replacement.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #5 on: 27 July 2018, 10:46:27 »
Best to measure the diameter of the threads and also the pitch, (the distance from one thread top to the next, If that makes sense). That will give you the dia. and pitch of the actual thread. HTH. :y
Keith ABS
  • Maldon Essex
« Reply #6 on: 27 July 2018, 13:15:20 »
 M6 thread then
Keith ABS
ronnyd
« Reply #7 on: 27 July 2018, 22:00:32 »
M6 thread then
Keith ABS
But what pitch?
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #8 on: 28 July 2018, 10:08:48 »
M6 thread then
Keith ABS
But what pitch?
Metric convention is that if you don't state it, then it's coarse.
So M6 actually means M6x1mm pitch.
Steve B
  • Leicestershire
« Reply #9 on: 28 July 2018, 16:19:29 »
Spot on aaronjb thats them...But what i done in the end is what Broomies mate said.. That white plastic thing came out easy along with a simple LED bulb..So all i need to do is get hold of a clear LED and put it back in.  :y
Automaticman
  • Neston
  • Saxwood
    • Frontera V6 Omega V6
« Reply #10 on: 02 August 2018, 00:55:27 »
When ya wanna shoot, shoot, dont talk !
