Author Topic: oil filler cap  (Read 3141 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
oil filler cap
« on: 05 August 2018, 00:13:38 »
has anybody ever had to replace an oil filler cap ? the one on my mig appears to work itself loose & oil ( only a small amount ) come out of the filler
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: oil filler cap
« Reply #1 on: 05 August 2018, 06:43:07 »
Mine did that too. I just fitted a new o ring into it.the old one had gone a bit hard.all fine since
raywilb
    • Citroen C4 Cactus
Re: oil filler cap
« Reply #2 on: 05 August 2018, 11:21:04 »
without checking isn't it a rubber washer . ?
Re: oil filler cap
« Reply #3 on: 05 August 2018, 11:28:24 »
Isn't an O ring a rubber washer?  ;D
raywilb
    • Citroen C4 Cactus
Re: oil filler cap
« Reply #4 on: 05 August 2018, 13:17:52 »
I have not seen that type of o ring for sale in any pack of o rings that I could buy from a motor factors. have you ? ;D ;D
Keith ABS
  • Maldon Essex
Re: oil filler cap
« Reply #5 on: 06 August 2018, 08:33:02 »
 I have filler cap rings in ABS.
£3 posted each
Keith ABS
Re: oil filler cap
« Reply #6 on: 06 August 2018, 09:27:09 »
I had to change the large o ring on one of mine. Same size used on cap and on filler neck to cam cover seal
deviator
  • Chesterfield
Re: oil filler cap
« Reply #7 on: 06 August 2018, 10:18:53 »
Sometimes, you can turn the rubber seal over and refit it and I've had limited luck with this working. To be honest a new 710 cap isn't that much and will probably be much cleaner.
    • 530D M Sport, 330i Coupe
Re: oil filler cap
« Reply #8 on: 06 August 2018, 18:20:46 »
Exactly the same here on a couple i've owned.  :y
