Author Topic: Air Conditioning Evaporator  (Read 4661 times)
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
« on: 05 August 2018, 10:52:11 »
Anybody know where this is?
Air con has a leak was going to buy a condenser and drier but thought i might take a look at the evaporator to check for leaks.
cheers
Re: Air Conditioning Evaporator
« Reply #1 on: 05 August 2018, 12:12:09 »
Isn't it the thing they build the car around ..... somewhere buried behind the dash?  :-\
Omega 37
  • Northampton
« Reply #2 on: 05 August 2018, 12:42:04 »
if its leaking id probably notice a wet carpet
« Reply #3 on: 05 August 2018, 12:50:18 »
Unlikely from a gas leak ::)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #4 on: 05 August 2018, 12:54:46 »
r134a refrigerant is a gas at room tempreture
the front rad condenser is common for leaking
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #5 on: 05 August 2018, 17:35:03 »
Fit the condenser / drier, then go to your local A/C place and have the go through the procedure of testing for leaks etc. before regassing it. If they don't find anything, well and good. If they do at least the dye they use should make it easier to find the leak.
Valves seem to be the most common problem and are cheapish and easy to replace. Don't think Ive heard of an evaporator leaking on an Omega.
jb
  • bucks
    • 3.2 Elite
« Reply #6 on: 06 August 2018, 07:57:01 »
3 most likely areas for leaks....condensor, fill valves and the flexi pipe which runs down the Pass side chassis leg under the battery and abs unit...i have some stock of these pipes.
Serek in Huntington at SOS an expert on ac and highly recommended.
Omega 37
  • Northampton
« Reply #7 on: 06 August 2018, 15:23:31 »
ok great i had load of pipework replaced years ago  hopefully the condenser :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #8 on: 07 August 2018, 11:05:09 »
 Never known an evaporator to fail, as others have said, first get it pressure tested with some nitrogen,if it holds the pressure,then system is good, the first place to check if it doesn't hold is the condenser, then the hp and LP valves, and the compressor,. If it is the evaporator, that's a dash board out job.
Best option if your not confident, is book it in with serek at SOS automotive here in hoof'land. :y
Hoof'land storeman.
