Author Topic: Front brake caliper slider pins lube question  (Read 10650 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« on: 14 August 2018, 08:42:31 »
It it OK to use this silicone grease on the front brake caliper slider pins to lube them up? I already have this handy.
Or is there a recommended grease to use?
« Last Edit: 14 August 2018, 08:53:05 by Andy A »
deviator
  • Chesterfield
Re: Front brake caliper slider pins lube question
« Reply #1 on: 14 August 2018, 09:03:54 »
Carfix
  • Malmesbury, Wiltshire
    • 1997 & 1998 Omega Elites
« Reply #2 on: 14 August 2018, 10:21:38 »
I have started using red rubber grease on the caliper sliders on my cars after years of using copper grease.
It doesn't effect the rubber covers, has not deterioated like copper grease over time and has remained stable with high temeratures.
Andy A
  • Bristol UK
« Reply #3 on: 14 August 2018, 10:24:23 »
It looks fine with rubber but there is no mention of temperature.
EDIT
https://www.ebay.co.uk/itm/Granville-Red-Rubber-Grease-Hydraulic-Lubricant-Brake-Caliper-Piston-500g-Tin/302636723893?epid=8015691171&hash=item46768deeb5:g:P8UAAOSwEYBagfKS
Like this. Don't use copper grease.
I think but I'm not sure -40degC to +200degC found in this link. https://www.lubesetc.com/silicone-grease-lubricants-22-c.asp. Will send them an email.
deviator
  • Chesterfield
« Reply #4 on: 14 August 2018, 10:25:30 »
It'll probably be fine. The Omega is hardly a point and squirt car.
Andy A
  • Bristol UK
« Reply #5 on: 14 August 2018, 12:06:58 »
I'll give it ago and if I get any problems will report back.  :y
Thanks all for your advice.  :y :y
deviator
  • Chesterfield
« Reply #6 on: 14 August 2018, 12:21:38 »
Glad to help, if indeed I did!
Andy A
  • Bristol UK
« Reply #7 on: 14 August 2018, 12:39:47 »
Any help or advice is always grateful.  :y
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #8 on: 14 August 2018, 13:06:25 »
IME, anything slippy will do. Copperslip. Grease. Margarine.
deviator
  • Chesterfield
« Reply #9 on: 14 August 2018, 15:07:05 »
Please don't use just anything slippy. Copperslip soaks into the rubbers over time and causes the rubbers to swell. This can lead to ineffective brakes. I'm not sure on the other suggested lubes, but personally I'd use the proper stuff. Granted, the sliders are less of an issue than the piston seal and dust capm but still.
« Reply #10 on: 14 August 2018, 15:22:46 »
Clearly never driven yours hard...
200° isn't enough. Use this at your peril.
deviator
  • Chesterfield
« Reply #11 on: 14 August 2018, 15:40:19 »
The reason I said 'probably' OK, is because whilst brakes get hot, the caliper brackets shouldn't be as hot as the friction surfaces. As most people measure the heat on the friction surfaces, I would have though 200 degrees is enough. But I'd use red brake grease in the first place.
EDIT
Urm, red brake grease specs....
1 x Granville Red Rubber Grease 500g Tin
Specification Information
Operating Temperature: -20°C to +120°C
Which is a little worrying.
« Last Edit: 14 August 2018, 15:43:11 by deviator »
« Reply #12 on: 14 August 2018, 16:09:57 »
The boiling point of DOT4 brake fluid is only 230 C, so if the caliper support has got up to 200 C I think the grease would be the last of your worries, TBH.
« Reply #13 on: 14 August 2018, 16:19:22 »
Food for thought*...
https://youtu.be/VEL9diENZY0
What happens to the front brakes on a heavy car used on an nsl dual carriageway with lots of roundabouts will get alot hotter for longer. If parked immediately after, then heat soak could become a concern.
*This test, whilst interesting, is on a light weight car which is stationary.
