Author Topic: Front brake caliper slider pins lube question  (Read 10658 times)
Re: Front brake caliper slider pins lube question
« Reply #15 on: 14 August 2018, 16:51:33 »
Nobody has mentioned the "TheBoy Milton Keynes" test, I notice. ::)
« Reply #16 on: 14 August 2018, 16:55:21 »
If I can induce brake fade between Horsham and Crawley, it comes as no surprise that he changes his pads every month ;D
« Reply #17 on: 14 August 2018, 16:59:51 »
I did that one with a 1700kg trailer with (as I later discovered) no brakes in July. ::)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #18 on: 16 August 2018, 17:35:56 »
The banjo front brake washers from Vauxhall. Can they be fitted anyway round?
The reason I ask is that I seen a you tube video once but can't find it now that stated they should be fitted a certain way round.
Thanks
« Reply #19 on: 16 August 2018, 18:08:18 »
And that's why I use LM on my sliders. And (proper) coppaslip on pad backings.
Across MK, if you try reasonably hard, you can exceed the limits of fresh, new DOT4.  200+ bhp, 1800kgs plus driver, small pads,  and if your unlucky, a need to come to a standstill every half a mile is hard on the brakes.
Andy A
  • Bristol UK
« Reply #20 on: 16 August 2018, 19:22:35 »
Whats that in English money?  ???
« Reply #21 on: 16 August 2018, 19:41:09 »
1.8 tons  ::)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #22 on: 16 August 2018, 19:52:23 »
RIP Paul Lovejoy
Andy A
  • Bristol UK
« Reply #23 on: 16 August 2018, 19:53:20 »
1.8 tons  ::)
Now that's a lot of weight. Must be the bigger V6 engine.  :)
« Reply #24 on: 16 August 2018, 20:18:15 »
They are all about the same, give of take 100kg depending on spec/gearbox
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #25 on: 16 August 2018, 20:51:08 »
From memory the handbook quotes a kerb weight for the F/L 3L Elite saloon as something like 1780lbs[could be slightly off on that figure]out of a 2200lb ton.Being pedantic 1800kgs is 1.8tonnes[not tons] :P ;D
« Reply #26 on: 16 August 2018, 22:04:27 »
Brings back memories of my mate's kit car when we were on our way to Ireland. From caliper stuck on a little, and got a tad warm, then the bearing grease melted, dripped out of the hub and melted the tyre sidewall on its way down. All from a triumph dolloposhite 1500 engine, and he didn't notice the drag until the bearing seized.
« Reply #27 on: 16 August 2018, 23:19:27 »
kilos  ???
2200lb isn't a ton it's a tonne  ::) ::) .... not that I'm being pedantic  ;) ;)
Indeed  ::)
BazaJT
« Reply #28 on: 17 August 2018, 07:21:54 »
You're quite correct :y Where was my maths last night? :-[ There are of course 2240lbs to the ton :-*
« Reply #29 on: 17 August 2018, 10:02:47 »
Food for thought*...
https://youtu.be/VEL9diENZY0
How about this test: https://www.youtube.com/watch?v=TPf4qwtr8Fs ;D :D :D
Slight brake bind, offside front. Pass and advise 😂😂😂
Well now I'm definitely bringing my cars to you for an MOT ;D ;D
