Author Topic: Wet carpets passenger side 2003 Corsa  (Read 9077 times)
« on: 26 August 2018, 16:57:08 »
My first thought was blocked scuttle drain like the Omega, but there doesn't seem to be much of anything behind the battery.
Windscreen seal itself?
Re: Wet carpets passenger side 2003 Corsa
« Reply #1 on: 26 August 2018, 17:04:49 »
I think I'll remove the battery for a better look......I have the radio code.
It was fine until a huge deluge a couple of weeks back.
Varche
  • Online Online
  • middle of Andalucia
    • Golf Estate
« Reply #2 on: 26 August 2018, 17:19:31 »
usually the drivers side - pedals seal.
Passenger side. Has the pollen filter not been sealed properly on refitment?
Blocked drain hole (leaves and the like)
bad grommet where the wiring from fusebox goes through into car?
You might have to remove the glove box to get a better view.
« Reply #3 on: 26 August 2018, 17:32:18 »
Thanks, Mr Varche,
I've had a quick look at the chavs who inhabit the Corsa forum (innit) and there are only so many things it can be. There was a lot of debris around the battery.
« Reply #4 on: 26 August 2018, 17:37:46 »
It's about time you cubed it and bought the long suffering Mrs Opti a decent car anyway!  :P
« Reply #5 on: 26 August 2018, 18:00:42 »
You go first with the Victorian BMW and then I'll follow. :)
« Reply #6 on: 26 August 2018, 18:05:19 »
My BMW is a modern classic  8) , whereas your Corsa is just a common or garden leaky chav-mobile that when cubed no-one will miss!  ::)
Mrs Opti deserves better!  ;D
« Reply #7 on: 26 August 2018, 18:35:07 »
Yes, of course it is. :).........I didn't realise it was so sought after. I apologise. ::)
Must be worth at least £30,000 and rising. A true classic like a 2002 Turbo or M1.
« Reply #8 on: 26 August 2018, 18:36:02 »
Mrs Opti deserves better than you. Someone like STEMO would look after her.
Steady on, Tig, you'll hurt his feelings.
« Reply #9 on: 26 August 2018, 18:36:50 »
Spooky. Just posted about one of them  :o
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #10 on: 26 August 2018, 18:47:12 »
That's because he's got one of each in an old barn on his sprawling estate. Now, if only he could remember which barn! :o :P
« Reply #11 on: 26 August 2018, 18:48:46 »
My money is on the battery tray...
Mk3 Granada did the same if the battery cover was left off...
Either a quick fix or some surgery*... :-\
*Mastic and flog it or welding :D
Varche
  • Online Online
    • Golf Estate
« Reply #12 on: 26 August 2018, 23:32:48 »
Two other solutions.
Buy a car cover
Or turf the tata out in the elements to make way for an under cover Corsa.
Did you join chavmyCorsa.com. Forum?
    • 530D M Sport, 330i Coupe
« Reply #13 on: 27 August 2018, 00:11:16 »
Fusebox seal (under scuttle)
« Reply #14 on: 27 August 2018, 11:51:10 »
Buy a car cover
No....the average age is thirteen and three quarters. :)
Page created in 0.022 seconds with 20 queries.
