Author Topic: Wet carpets passenger side 2003 Corsa  (Read 9087 times)
Re: Wet carpets passenger side 2003 Corsa
« Reply #15 on: 27 August 2018, 11:55:40 »
Two other solutions.
Buy a car cover
Or turf the tata out in the elements to make way for an under cover Corsa.
Did you join chavmyCorsa.com. Forum?
No....the average age is thirteen and three quarters. :)
It can't be. They'd have to be at least 17.  :)
« Reply #16 on: 27 August 2018, 12:16:56 »
Buy a car cover
I suspect the average age of a derv Astra owner is considerably higher.   In three figures perhaps. :)
Having said that Jag/Tata owners tend to be pretty long in the tooth. Probably the reason why dullards and old farts on the Jag Info forum banned me (twice) :)
« Last Edit: 27 August 2018, 12:20:34 by Field Marshal Dr. Opti »
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #17 on: 27 August 2018, 12:23:52 »
Fusebox seal (under scuttle)
Yep..done a few...take out screws and the seal will be broken..you can use a sealant or buy a new one with seal..But sealant does the job..
https://www.ebay.co.uk/itm/VAUXHALL-CORSA-C-FUSE-RELAY-BOX-COVER-LID-2000-TO-2006-GENUINE-PART-FITS-COMBO/273183841609?hash=item3f9b069d49:g:dscAAOSwKtVWzL2z
And when its drivers side leak it is the sealant around the brake servo gone hard and leaking.. :y
« Reply #18 on: 27 August 2018, 12:28:14 »
Thanks VXL and Steve.
Right next to the battery. I'll take a look and see if it is the culprit. :y
Steve B
  • Leicestershire
« Reply #19 on: 27 August 2018, 12:33:59 »
« Reply #20 on: 27 August 2018, 12:47:20 »
Scuttle off and batt out  :y
https://www.youtube.com/watch?v=9Skta25yk_U
Thanks. I'm surprised he is using draught excluder though. Can't think it would be waterproof.
« Reply #21 on: 27 August 2018, 13:59:14 »
I would hardly think it's worth the effort even lifting the bonnet, given you'll be paying someone to take it away before long.....  :-\
« Reply #22 on: 27 August 2018, 14:15:04 »
Envy is a terrible thing, Sir Tig. :)
I imagine the bonnet on the elderly Bavarian is up and down more often than STMO's trousers.........and probably leaks about the same amount.
« Reply #23 on: 27 August 2018, 14:48:57 »
Don't be bringing me into it. Why don't you both just sell your cars, put the money together, and buy an ice cream or something.  ;D
« Reply #24 on: 27 August 2018, 15:03:28 »
I doubt that the Corsa that poor Mrs Opti is forced to drive is even worth an ice cream to be honest.  :-\
My car from the stable of Bayerische Motoren Werke however.  :)
« Reply #25 on: 27 August 2018, 15:10:23 »
My car from the stable of Bayerische Motoren Werke however...........
.........is worth a 99 with two flakes  :y
« Reply #26 on: 27 August 2018, 15:17:32 »
Don't you bleddy start!  ;D
« Reply #27 on: 27 August 2018, 15:51:00 »
.....I'd add a choc ice if it came with a full tank of derv. :)
« Reply #28 on: 27 August 2018, 17:20:10 »
Mrs Opti would be very appreciative I'm sure if you replaced the leaky Corsa with a modern classic BMW finished in Royal Red with a sports interior!  :y
A 99 with 2 flakes and a choc ice seems reasonable, but I can only let you have it on a delivery only basis M'lud and there will be a modest charge for delivery of course!  :)
