Author Topic: Fuel hose size inside fuel tank  (Read 3068 times)
mandula
  • Finland
    • Opel Omega -03, Z22XE man
« on: 04 September 2018, 08:19:00 »
Hi,
I'm upgrading my Omega to be used also with ethanol mixture.
I've already installed the kit (https://eflexfuel.com/en) and approved it at MOT. Government will also give me 200 e support so all together it was 190e + 1 hour own work to get it working.
Kilometer counter just went over 330 000 km, so will in advance replace fuel pump and also want to replace hoses inside tank to stuff that wont become brittle if I have only E85 in the tank.
So, does anybody have information what size of hose should I get inside the fuel tank?
Re: Fuel hose size inside fuel tank
« Reply #1 on: 04 September 2018, 09:55:04 »
I/D is 6mm iirc ;)
mandula
  • Finland
« Reply #2 on: 04 September 2018, 10:24:47 »
Thanks  :y
mandula
  • Finland
« Reply #3 on: 04 September 2018, 11:01:45 »
Found a hose that can handle immersing inside ethanol/any fuel:
Cohline type 2190 - ID7,3/OD13,5 max 10bar
I think that will do the trick  :)
« Reply #4 on: 04 September 2018, 11:29:14 »
My usual recommendation...
https://www.vetus.com/en/fuel-systems/fuel-hoses/fuel-hose-12083.html
Not sure how it works with ethanol though :-\
Actually all good...
https://www.iso.org/standard/59437.html 8)
« Last Edit: 04 September 2018, 11:36:23 by Doctor Gollum »
